When a DVD recorder records to a disc in extended play format, how does it do this? Is it still in mpeg2 format, just at a lower bitrate? or is it lowered into mpeg1 format? In either case, does anyone know the associated bitrates?
Results 1 to 13 of 13
From a few of the posts that I have seen here...on a few of the recorders, the bitrate never changes between speed settings.
But as guns1inger pointed out, the best way to find out is to experiment.Google is your Friend -
It has to change, the bitrate is the amount of data being used per second. As the bitrate changes the amount of disc space required changes. You can't have more or less disc space for without changing the bitrate.Originally Posted by Krispy Kritter
That's what I thought. But he posted here asking why his DVD recordings in SP or LP were both recording at a bitrate of 8000. If I can find the post, I'll link to it.
It may be it's using a variable bitrate with the max being 8000 for both but with a lower minimum and average bitrate for the extended play.Originally Posted by Krispy Kritter
The 4 hour mode is typically 2.5 Mbits/sec at 1/2 D1 (360x480 NTSC) which is also the SVCD spec.
Some call 4-hour "EP" and some call 6-hour "EP"
Depending on the unit, 4-hour may be okay.
The 6-hour will always look like crap.Want my help? Ask here! (not via PM!)
Actually, iirc ntsc svcd is 480x480 (2/3 D1). This isn't a very high bitrate for that resolution, and my tries at these tended to show artifacts.Originally Posted by pjcrown
What is "half D1" exactly? I've seen it mentioned before, but I don't know what it is.
It sounds like it lowers the quality of the video file? To make it smaller? -
nathanaa - read here https://www.videohelp.com/dvd
Read my blog here.
D1 is 704x480NTSC(576PAL)fullscan, or 720x480/576 overscan
1/2 D1 is half the fullscan horiz. rez or 352x480/576
both of these use MPEG2 in DVD's
DVD's can also make use of what might be called 1/4 D1, but is more properly called SIF (or CIF): 352x240 part of MPEG1
Scott -
As mentioed it's lower resolution with less detail but if your using lower bitrates is preferable because it will eliminate macroblocking that starts to occur around 4000 kbps when using 720x480.Originally Posted by nathanaa
720x480 @3000 kbps
352x240 @3000 kbps (not half D1 but lower)
how or where (if you can) can you format a dvd disk with no recorder?
By noclue in forum Newbie / General discussionsReplies: 3Last Post: 19th Oct 2011, 14:11 -
DVD Recorder Widescreen Format
By TLA in forum DVD & Blu-ray RecordersReplies: 11Last Post: 30th Jan 2010, 10:25 -
Any Programs Have Better System than Long Play, Extended Play?
By johnharlin in forum Video ConversionReplies: 3Last Post: 10th Jul 2009, 20:04 -
From video camcorder to DVD format using Sony Recorder
By Noek in forum Newbie / General discussionsReplies: 7Last Post: 24th Nov 2008, 22:00 -
need help with Nero 8 and Nero Vision 5 (figuring Extended Play Plus)
By Edward Benavides in forum Newbie / General discussionsReplies: 2Last Post: 31st Oct 2007, 12:10
