im new to creating dvds,,but i use TMPGEnc 3.0 XPress & TMPGEnc DVD author for creating some dvds and somtimes i use WinAvi,any way,
my proble is i got this japaness movie,In the folder u got 4 files,,CD1.avi & CD2.avi the CD1.srt & CD2.srt
my problem is i want to have this movie as a DVD !! HOW![]()
this is how i would do it:
open virtualdub and open the first avi then go to file and click on"append new avi" and load the second one and then save it using "direct stream copy" function.
open subtitle workshop and combine the 2 sub files into 1 file and save as sst file. if sync problems appears use SubSync to sync the sub.
then use your Tmpgenc to convert the avi to dvd
now demultiplex your dvd to elementary streams using vobedit.
load muxman, load your elementary video and audio aswell as your sst file and burn.
i dont know if tmpg encodes to dvd and outputs as elementary streams if it does you dont need to use vob edit
sorry for the bad englishI love it when a plan comes together! -
i think you only need to use virtualdub to join the avi's and subtitle workshop to join the srt's. your tools can do the rest of the process.
Avi Movie files shut off towards the end on Home DVD player.
By mrxny in forum Newbie / General discussionsReplies: 2Last Post: 11th Oct 2011, 00:24 -
How to Convert DVD files to .mpg/.wmv/avi for editing in Win Movie Maker
By Injasuti in forum Newbie / General discussionsReplies: 4Last Post: 8th May 2011, 04:47 -
Convert .avi movie files to vcd or dvd without loosing picture quality
By akakiami in forum Video ConversionReplies: 8Last Post: 8th May 2010, 18:01 -
I have a problem using Ulead DVD Movie factory including.AVI Files, the pro
By OggO1984 in forum Authoring (DVD)Replies: 1Last Post: 19th Dec 2009, 09:42 -
Movie in 2 avi files but with different resolutions
By LaLuna in forum Video ConversionReplies: 4Last Post: 24th Nov 2007, 22:00
