Hi friends! I have two AC3 files (5.1), and i want to join it. How can I do this, and what is the better software to do it (Besweet, Sound Forge, etc...)?
Thanks a lot for the help!!
Results 1 to 9 of 9
You can use besplit(command line tool),
Let's say you want to join stream1.ac3,stream2.ac3,stream3.ac3 into stream.ac3.
Create a listfile called join.lst in notepad:
stream1.ac3
stream2.ac3
stream3.ac3
Use BeSplit from a command line or use start->run and typ:
c:\locationto\besplit.exe -core( -input join.lst -output stream.ac3 -type ac3 -join )
(change the c:\locationto and put besplit and all ac3 and the .lst files in same folder)
this is from doom9s audio faq...first hit if you search for "join ac3" using google.
You can also use the copy /b from the command line or start->Run:
copy /b part1.ac3+part2.ac3 both.ac3
and then run ac3fix on the both.ac3 to check that it is correct. -
BeSplit does not work (stable version 0.8 returns nothing more than syntax information, beta 0.9b returns error creating output file "null").
Simply copy /b and ac3fix looks like working solution, but actually ac3fix change nothing. (As well as besliced and besplit -fix). Does it mean that it does not recognize ac3 header appeared in the middle of the file? Is it possible at all since it does not different from audio frame?
We do need working ac3/mp3/aac joining program... -
MPEG Video Wizard DVD does it.Originally Posted by rgraiche
Well, for MP3 use MP3DirectCut.Originally Posted by lovyagin
Cut and paste MP3 editing without reencoding. -
Sorry for posting in this very old thread but I have a serious question.
I used MPEG Video Wizard DVD to join my ac3 files together. It worked fine. I'm wondering if this was a simple merge without re-encode or if MPEG video Wizard did a re-reencode.
Let me know
thanks
-Gwar
Split, join, create silence of an ac3 file
By phate89 in forum AudioReplies: 6Last Post: 16th Jul 2011, 14:34 -
How Do I Join M2V and AC3 Files?
By lovelylisa in forum Video ConversionReplies: 1Last Post: 6th Jun 2011, 18:13 -
How to join ac3 files?
By X_Splinter in forum AudioReplies: 9Last Post: 30th May 2010, 10:10 -
Join .MP4 with .AC3 to .MKV without loss of sync
By vanleeuwen in forum Video ConversionReplies: 2Last Post: 18th Dec 2008, 03:53 -
Using Submerge to Join avi Files to srt Files: Problems with Export
By TiggyWink in forum MacReplies: 1Last Post: 26th Jun 2007, 09:16
