Hi I have a problem when I open a file in VirtualDubMod to extract the audio it says can't find a way to decompress it. However I can play the file and the audio works fine. In GSpot it says it's DSAT wave audio. So does anyone know where I can find that codec. I looked in the forum but this: https://www.videohelp.com/forum/viewtopic.php?t=265485&highlight=dsat
is all I found and that doesnt work. Any help would be appreciated.
VirtualDubMod requires an ACM decoder. Quite possible that there isn't one.
Nope I installed that decoder and it still won't work. Any other suggestions?
I'm trying to decompress it to wave to then recompress it to AC3 to burn onto a DVD. Anything?
Well if the link was to a dshow/DMO decoder then graphedit as suggested would work.
Although from your reply maybe it is an ACM decoder? If so then it really should work with VirtualDubMod.
convert video with Photo JPEG codec and MS IMA APMCD audio codec
By devil_doll in forum Video ConversionReplies: 3Last Post: 21st Jan 2011, 14:10 -
Which Codec's is Best To Use?
By Artic in forum Video ConversionReplies: 4Last Post: 26th May 2010, 14:39 -
Can Codec ID/Codec Hint make a difference on the video?
By dzsoul in forum Video ConversionReplies: 2Last Post: 1st Jun 2009, 19:40 -
MPG File with ivivideo Codec-bad picture.Can I change the codec?
By cska133 in forum Software PlayingReplies: 13Last Post: 4th Nov 2008, 09:41 -
Re-Codec
By Casper_H in forum AudioReplies: 1Last Post: 21st Feb 2008, 08:10
