I want to convert a Video_TS folder into an .avi Xvid file with mencoder. I used the video-bitrate the calculator told me and put the following options on: crop, high quality, two-pass encoding, trellis quantization, quarter pixel ME, billinear
thats all right with every video_TS folder, except two. they just turn out with the final filesize about 120 MB too big. so i lowered the bitrate, but the filesize was still 120 MB too big. whats the problem here?
i hope somebody can help me
Send me to major4@mac.com the process outputs, maybe the could contain hints about which is the difference between those encodings.
Major, I'm getting a similar problem. I'm encoding to .AVI using Xvid (mencoder) with crop, high quality, b-frames, 2-pass, trellis, qpel, bicubic spline The video track being converted is Track 16. The audio track is being converted from 5.1 -> stereo MP3 (48000Hz, 128 kbps, gain +9). Regardless of what value I put in for the bitrate, the final AVI is the same size at 1.21 GB - way too large to put on a CD.
Here's my terminal output using a 933 kbit/sec video setting
Last login: Sun Aug 14 12:30:59 on ttyp1
/Applications/ffmpegX\ 0.0.9s/ffmpegX.app//Contents/Resources/pbpaste | sh
Welcome to Darwin!
emacs-emac:~ emac$ /Applications/ffmpegX\ 0.0.9s/ffmpegX.app//Contents/Resources/pbpaste | sh
Encoding started on Sun Aug 14 12:35:06 CDT 2005
MEncoder dev-CVS-050123-19:55-3.3 (C) 2000-2005 MPlayer Team
Mac OSX static build for ffmpegX
AltiVec found
CPU: PowerPC
File not found: 'frameno.avi'
Failed to open frameno.avi
libdvdread: Couldn't find device name.
Reading disc structure, please wait...
There are 20 titles on this DVD.
There are 23 chapters in this DVD title.
There are 2 angles in this DVD title.
DVD successfully opened.
success: format: 0 data: 0x0 - 0x2142e800
MPEG-PS file format detected.
VIDEO: MPEG2 720x480 (aspect 3) 29.970 fps 6000.0 kbps (750.0 kbyte/s)
[V] filefmt:2 fourcc:0x10000002 size:720x480 fps:29.97 ftime:=0.0334
Opening audio decoder: [liba52] AC3 decoding with liba52
Using AltiVec optimized IMDCT transform
AC3: 5.1 (3f+2r+lfe) 48000 Hz 448.0 kbit/s
Checking for AltiVec resampler : 0x0000000a, 2
Using AltiVec optimized resampler
AUDIO: 48000 Hz, 2 ch, 16 bit (0x8), ratio: 56000->192000 (448.0 kbit)
Selected audio codec: [a52] afm:liba52 (AC3-liba52)
xvid: using library version 1.1.-126 (build xvid-1.1.0-beta1)
Opening video filter: [expand osd=1]
Expand: -1 x -1, -1 ; -1 (-1=autodetect) osd: 1
Opening video filter: [scale w=560 h=304]
Opening video filter: [crop w=710 h=460 x=6 y=6]
Crop: 710 x 460, 6 ; 6
Opening video decoder: [mpegpes] MPEG 1/2 Video passthrough
VDec: vo config request - 720 x 480 (preferred csp: Mpeg PES)
Could not find matching colorspace - retrying with -vf scale...
Opening video filter: [scale]
The selected video_out device is incompatible with this codec.
VDecoder init failed
Opening video decoder: [libmpeg2] MPEG 1/2 Video decoder libmpeg2-v0.4.0b
Selected video codec: [mpeg12] vfm:libmpeg2 (MPEG 1 or 2 (libmpeg2))
MP3 audio selected
Building audio filter chain for 48000Hz/2ch/16bit -> 48000Hz/2ch/16bit...
Writing AVI header...
ODML: Aspect information not (yet?) available or unspecified, not writing vprp header.
Setting audio input gain to 9.000000
VDec: vo config request - 720 x 480 (preferred csp: Planar YV12)
VDec: using Planar YV12 as output csp (no 0)
Movie-Aspect is 1.78:1 - prescaling to correct movie aspect.
SwScaler: reducing / aligning filtersize 27 -> 16
SwScaler: reducing / aligning filtersize 32 -> 16
SwScaler: Bicubic spline scaler, from Planar YV12 to Planar YV12 using AltiVec
videocodec: XviD (560x304 fourcc=44495658 [DIVX])
xvid: par=0/0 (vga11), displayed=560x305, sampled=560x304
xvid: bitrate setting is ignored during first pass
xvid: 2Pass Rate Control -- 1st pass
ODML: vprp aspect is 16384:8923. Trem: 0min 0mb A-V:0.003 [0:0]
1 duplicate frame(s)!
Pos: 0.3s 9f ( 0%) 0fps Trem: 0min 0mb A-V:0.027 [0:0]
Skipping frame!
Pos: 0.5s 14f ( 0%) 0fps Trem: 0min 0mb A-V:0.043 [0:0]
Skipping frame!
Pos: 0.8s 24f ( 0%) 17fps Trem: 0min 0mb A-V:0.077 [0:128]
Skipping frame!
Pos: 0.9s 27f ( 0%) 18fps Trem: 0min 0mb A-V:0.084 [0:127]
Skipping frame!
Pos: 0.9s 29f ( 0%) 18fps Trem: 0min 0mb A-V:0.047 [0:128]
Skipping frame!
Pos: 1.3s 39f ( 0%) 19fps Trem: 0min 0mb A-V:0.060 [20:128]
Skipping frame!
Pos: 1.4s 44f ( 0%) 19fps Trem: 0min 0mb A-V:0.043 [19:128]
Skipping frame!
Pos: 1.8s 54f ( 0%) 19fps Trem: 0min 0mb A-V:0.010 [17:127]
Skipping frame!
Pos: 1.9s 59f ( 0%) 19fps Trem: 0min 0mb A-V:-0.007 [17:128]
Skipping frame!
VDec: vo config request - 720 x 480 (preferred csp: Planar YV12)[17:128]
Pos: 2.0s 62f ( 0%) 18fps Trem: 0min 0mb A-V:-0.010 [17:128]
Pos: 2.2s 68f ( 0%) 18fps Trem: 0min 0mb A-V:0.010 [23:128]]
Pos: 2.3s 70f ( 0%) 18fps Trem: 0min 0mb A-V:0.016 [22:128]
demux_mpg: 24fps progressive NTSC content detected, switching framerate.
Pos:2982.6s 71525f (66%) 17fps Trem: 36min 1137mb A-V:0.084 [1984:128]]
Skipping frame!
VDec: vo config request - 720 x 480 (preferred csp: Planar YV12) [1995:128]
Pos:5471.8s 131208f (100%) 31fps Trem: 0min 1388mb A-V:0.024 [1995:128]
Pos:5472.0s 131214f (100%) 31fps Trem: 0min 1388mb A-V:0.049 [1995:128]
demux_mpg: 30fps NTSC content detected, switching framerate.
Warning! FPS changed 23.976 -> 29.970 (-5.994000) [4] -V:0.054 [1995:128]
Pos:5472.3s 131220f (100%) 31fps Trem: 0min 1388mb A-V:0.071 [1995:128]
Flushing video frames
CBR audio: 16000 bytes/sec, 384 bytes/block
Writing AVI index...
Fixing AVI header...
Video stream: 1995.562 kbit/s (249445 bps) size: 1365040487 bytes 5472.306 secs 131220 frames
Audio stream: 128.000 kbit/s (16000 bps) size: 87564288 bytes 5472.768 secs
AltiVec found
CPU: PowerPC
MP3 audio selected
xvid: 2Pass Rate Control -- 2nd pass -- bitrate=933kbit/s
Skipping frame!
Skipping frame!
Pos: 0.8s 24f ( 0%) 18fps Trem: 0min 0mb A-V:0.077 [0:128]
Skipping frame!
Skipping frame!
Pos: 0.9s 29f ( 0%) 19fps Trem: 0min 0mb A-V:0.047 [0:128]
Skipping frame!
Skipping frame!
Skipping frame!
Skipping frame!
Skipping frame!
VDec: vo config request - 720 x 480 (preferred csp: Planar YV12)[16:128]
Pos: 2.0s 62f ( 0%) 19fps Trem: 0min 0mb A-V:-0.010 [16:128]
Pos: 2.2s 68f ( 0%) 19fps Trem: 0min 0mb A-V:0.010 [22:128]]
Pos: 2.3s 70f ( 0%) 19fps Trem: 0min 0mb A-V:0.016 [21:128]
Pos:2982.6s 71525f (66%) 17fps Trem: 36min 1020mb A-V:0.084 [1767:128]]
Skipping frame!
VDec: vo config request - 720 x 480 (preferred csp: Planar YV12) [1761:128]
Pos:5471.8s 131208f (100%) 31fps Trem: 0min 1235mb A-V:0.024 [1761:128]
Pos:5472.0s 131214f (100%) 31fps Trem: 0min 1235mb A-V:0.049 [1761:128]
Warning! FPS changed 23.976 -> 29.970 (-5.994000) [4] -V:0.054 [1761:128]
Pos:5472.3s 131220f (100%) 31fps Trem: 0min 1235mb A-V:0.071 [1761:128]
Video stream: 1761.506 kbit/s (220188 bps) size: 1204937664 bytes 5472.306 secs 131220 frames
Encoding completed on Mon Aug 15 02:55:44 CDT 2005
emacs-emac:~ emac$
And here's the output I get when I halve the video bitrate setting to about 477 kbit/sec
Last login: Fri Aug 12 19:42:58 on ttyp1
Welcome to Darwin!
Encoding started on Fri Aug 12 22:53:20 CDT 2005
AltiVec found
CPU: PowerPC
MP3 audio selected
Pos: 0.3s 9f ( 0%) 8fps Trem: 0min 0mb A-V:0.027 [0:0]
Skipping frame!
Pos: 0.5s 14f ( 0%) 8fps Trem: 0min 0mb A-V:0.043 [0:0]
Skipping frame!
Pos: 0.8s 24f ( 0%) 9fps Trem: 0min 0mb A-V:0.077 [0:128]
Skipping frame!
Pos: 0.9s 27f ( 0%) 10fps Trem: 0min 0mb A-V:0.084 [0:127]
Skipping frame!
Pos: 0.9s 29f ( 0%) 10fps Trem: 0min 0mb A-V:0.047 [0:128]
Skipping frame!
Pos: 1.3s 39f ( 0%) 10fps Trem: 0min 0mb A-V:0.060 [20:128]
Skipping frame!
Pos: 1.4s 44f ( 0%) 10fps Trem: 0min 0mb A-V:0.043 [19:128]
Skipping frame!
Pos: 1.8s 54f ( 0%) 10fps Trem: 0min 0mb A-V:0.010 [17:127]
Skipping frame!
Pos: 1.9s 59f ( 0%) 10fps Trem: 0min 0mb A-V:-0.007 [17:128]
Skipping frame!
Pos: 2.0s 62f ( 0%) 10fps Trem: 0min 0mb A-V:-0.010 [17:128]
Pos: 2.2s 68f ( 0%) 10fps Trem: 0min 0mb A-V:0.010 [23:128]]
Pos: 2.3s 70f ( 0%) 10fps Trem: 0min 0mb A-V:0.016 [22:128]
Skipping frame!
AltiVec found
CPU: PowerPC
MP3 audio selected
xvid: 2Pass Rate Control -- 2nd pass -- bitrate=477kbit/s
Skipping frame!
Pos: 0.5s 14f ( 0%) 9fps Trem: 0min 0mb A-V:0.043 [0:0]
Skipping frame!
Skipping frame!
Pos: 0.9s 27f ( 0%) 9fps Trem: 0min 0mb A-V:0.084 [0:127]
Skipping frame!
Skipping frame!
Skipping frame!
Skipping frame!
Skipping frame!
Skipping frame!
Pos: 2.0s 62f ( 0%) 10fps Trem: 0min 0mb A-V:-0.010 [16:128]
Pos: 2.2s 68f ( 0%) 10fps Trem: 0min 0mb A-V:0.010 [22:128]]
Pos: 2.3s 70f ( 0%) 10fps Trem: 0min 0mb A-V:0.016 [21:128]
Skipping frame!
Encoding completed on Sat Aug 13 21:14:51 CDT 2005
emacs-emac:~ emac$
As you can see, even though the specified bitrates are extremely different, the final video streams end up the same size. Any insights as to what's going on?
This problem has apparently been around for a while...
https://www.videohelp.com/forum/viewtopic.php?t=259502
I have the same problem with mencoder DivX. I choose to convert a VIDEO_TS folder to AVI DivX with the following options: 140 min on 1 80m mode-1 700 MB CD-R (using the auto button for the bitrate and screen size), 128 kbit/s audio bitrate (sampling: 44100 Hz) VBR, autocrop, high quality, 4 motion vectors, 2-pass encoding, trellis quantization, quarter pixel ME, billinear (SSE), qmin=3, qmax=9.
The resulting AVI file size is still too large to fit on a 700 MB CD. It's actually almost 800 MB.
I'm a bit confused. Isn't two-pass encoding supposed to alter the bitrate after the first pass so the file doesn't end up being smaller/bigger than the intended file size?
(I'm asking this, because before I switched to Macs, I used to convert VIDEO_TS folders with GordianKnot, which did the trick ...)
my xvid videos are too big in filesize
By C-Royd in forum Video ConversionReplies: 1Last Post: 6th Aug 2011, 17:31 -
Reducing Filesize of .avi
By jonesb in forum Newbie / General discussionsReplies: 5Last Post: 4th May 2009, 12:01 -
Reduce VOB filesize
By jacktorrance in forum Video ConversionReplies: 8Last Post: 14th Jan 2009, 12:34 -
Reducing filesize
By caper in forum Video ConversionReplies: 19Last Post: 7th Dec 2008, 20:22 -
Big big troubles with firewirre PCI card.
By SE14man in forum Newbie / General discussionsReplies: 1Last Post: 1st Mar 2008, 00:51
