Looking for the most stable version of ATI software and drivers (mmc, catalyst) to be installed on AMD 1.8ghz w/1meg ram, AIW 9800 pro, and win xp pro (sp1). have had issues w/MMC versions in the past and looking to do clean install from o/s up.
-P-
Results 1 to 9 of 9
I have read elsewhere that 4.12 Catalyst, and the 9.03 MMC seem to play the best and be most stable...
Shuttle SH55-J2-BK-V1 w/4.00gb Ram, INTEL i3-550, 3.2ghz, WIN7 home premium 64bit
hauppauge 950q, 1600, 1250 -
8.7 is most stable
9.02 may be decent tooWant my help? Ask here! (not via PM!)
With WinXP, ATI 9800 Pro, P4 3.0 (800fsb) - 9.03 has been stable for me, except:
Prob: Anywhere from 15 min to 1.5 hours the capture program freezes - so bad the system has to have a hard shutdown / restart. I finally found in the depths of ATI that this is a problem with hyper-threading and there is a hotfix available from Microsoft. For $35, it is possible to call Microsoft and get told that SP2 includes the hotfix and it isn't available.
But hyperthreading is indeed the cause. Going to CMOS and disabling hyperthreading absolutely fixes the issue. Then the ATI capture program works really great - particularly with Lordsmurf's wonderful set of instructions posted here. No more freezes. Just go set CMOS before capturing, then reset it back when finished. A little hassle, but solid workaround.
I've not managed to get anything later than 8.9 to work properly so thats what I run. 8.7 or 8.9 seem to be about the most stable.
Wondering about two "identical" WS versions of a film...
By takearushfan in forum Newbie / General discussionsReplies: 22Last Post: 25th Mar 2012, 08:57 -
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 02:52 -
WMV files: Changing "Recorded Date", "Media Created" fields in metadata
By axhack in forum EditingReplies: 5Last Post: 18th Sep 2010, 02:27 -
"stretching" or "cramming" aspect ratio when I convert .avi to MP4
By Agent Bauer in forum ffmpegX general discussionReplies: 3Last Post: 21st Mar 2010, 11:30 -
Editing self-owned dvd movies to make "clean versions" for my fam
By nef1l1m in forum EditingReplies: 5Last Post: 1st Aug 2007, 15:00
