Hi,
some of you have missed some features in VDstart! So I have now written VDstart Pro with all features you want.
VDstartPro has this features:
- Support for VirtualDub clones like NanDub
- VirtualDub can be started automatically
- You can use commandlineparameters to control VirtualDub.
- The captured files can be automatically renamed after capturing in up to 214748364799 several files
with the same given name.
- Joblist, wich you can use for endless much commands like start/stop capture, rename, run file
and shut down system to a date/time of your choice.
- I have added a feature which helps me to help you with problems.
- VDstartPro doesn't write anything into your registry! All settings are saved in an INI-file. VDstartPro
only reads the VirtualDub capture path, if you haven't saved the settings.
If you are interested, you can download the currect version under:
http://www.geocities.com/sssoftfil01/eigene/VDstartPro1B/vdstartpro1beta.html
If you have any problems, questions or if you are missing a option feel free to write me a mail: sssoft2001@yahoo.de
Best regards
Simon S.
Have just noticed that the Link was down...
here's a new one:
http://www.geocities.com/GeoFileSer0002/eigene/VDstartPro1B/vdstartpro1beta.html
mfg
TKS
VirtualDub video skipping while capturing
By kurtdani in forum Capturing and VCRReplies: 21Last Post: 4th Dec 2011, 14:48 -
virtualdub capturing
By cesar110 in forum Capturing and VCRReplies: 1Last Post: 6th Aug 2011, 23:17 -
Capturing DV - Editing with Virtualdub
By LSchafroth in forum Capturing and VCRReplies: 5Last Post: 27th Nov 2009, 20:19 -
Bitrates, capturing with VirtualDub
By epicap in forum Capturing and VCRReplies: 4Last Post: 3rd Sep 2009, 10:49 -
Capturing using Virtualdub with Vista
By qwerty99 in forum Capturing and VCRReplies: 17Last Post: 27th Feb 2009, 20:59
