Hi,
I've got some avi files that are running at 23.976fps so i've used divxtodvd, changed the files to 25fps and burnt them to a dvd. Audio is out of sync though.
Something similar has happened before. I used to burn avi files that were 23.976fps to a cd-r which also ran out of sync when played back. I thought I might have to change it to PAL, 25fps, but they also ran out of sync when played back on my dvd player.
It seems whatever frame rate they are burnt as the audio will always be buggered.
Anyone got any ideas? Thanks guys.
Perhaps try one of the other similar apps, such as AVI2DVD, The Film Machine, etc.
This happens all the time. Extract the audio using Virtualdub and convert the audio to 25fps separately from the video. You can always join the two files later when you author.
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 22:09 -
Audio Sync Problem
By lwea2009 in forum Newbie / General discussionsReplies: 8Last Post: 30th May 2009, 16:19 -
out of sync audio problem
By virendra in forum AudioReplies: 2Last Post: 25th Dec 2007, 07:31 -
New (?) audio sync problem
By oldblues in forum ffmpegX general discussionReplies: 3Last Post: 26th Oct 2007, 11:26 -
divxtodvd problem
By BPH2002 in forum Newbie / General discussionsReplies: 31Last Post: 27th Jun 2007, 09:17
