Hello- searched forums and previous topics and couldn't find the simple newbie reference to "which is the best user- friendly (multi function/ freeware) AVI to MPEG2 converter". I have Nero6Ultra and i don't believe it does this conversion. Don't mind paying reasonable cost if it's flexible and guey friendly. thanx Mike
Results 1 to 12 of 12
There are no free MPEG2 converters as far as I know. If you buy a DVD writer or a new Digital Camcorder, they may come with some packages which can create DVD's - but probably not independant MPEG2 files.
Most encoders such as TMPGEnc, Mainconcept, etc. come with a free trial MP2 converters. You may have something like 15 days before the trial period expires. Nero6 Ultra should have a MPEG2 converter called Nero Recode but it lacks in quality IMHO.
If you check from the tools section you can get an approximate price of each tool. I don't think anyone will tell you that so-and-so encoder is the best because that will start a war of words. It is a matter of personal choice.
Personally I like TMPGEnc and Mainconcept.*** My computer can beat me at chess, but is no match when it comes to kick-boxing. *** -
Software MPEG2 conversion tools are not free, but can be relatively inexpensive (like, $50). Most of them offer a trial period where you can check them out for free.
Another much faster alternative is a standalone DVD recorder with DV firewire input (if you are converting directly from digital camcorder tapes). You could also look at a hardware MPEG encoding capture card like the Hauppauge 250. Both options perform real time conversion. Software encoding can be painfully slow. -
QuEnc is a free (and pretty good at that!) mpeg2 encoder. User friendly? Well, that depends on the user...
/Mats -
Most of freeware mpeg2 encoders are not newbee user-friendly because they require Avisynth frameserving. The user-friendliest seems to be VSO DivxtoDVD, though the output is sometimes not so good.
Another option might be bbMPEG, but it is slow. Maybe some one-click packages are somewhat more newbee usable as DVD2SVCD (it has AVI2DVD functionality) or maybe Avi2DVD (this is another package) -
VSO DivXtoDVD - It's great, and takes AVI files. Oh, and it is free.
To Mats Hogberg:
I tried the QuEnc converter. Upon opening, I directed it to the Avi I wanted to convert to Mpeg2. It did not see it in the explorer window till I specified "all files". then when i hit encode it gave an error message:
"AviSynth open failure Script erro. there is no function named "Convert to YV12" ...aparently can't see an Avi filetype. This is a true ave that will open in Winamp I want to convert to Mpeg. Any ideas? or does this refer to the "user friendly" issue? thanx Mike -
This is the 'user friendly' issue.I tried the QuEnc converter. Upon opening, I directed it to the Avi I wanted to convert to Mpeg2. It did not see it in the explorer window till I specified "all files". then when i hit encode it gave an error message:
As Abond mentioned, Quenc requires an Avisynth script so you can't point it directly at the avi. The Avisynth script must identify the avi file and will probably require the ConvertToYV12 function (depending on the source) as a minimum script.
Buy My Books
A converter from AVI to MPEG2 without any lose please???
By microlab1986 in forum Video ConversionReplies: 4Last Post: 17th Jun 2009, 06:08 -
WMV to MPEG2 converter
By siluet in forum Video ConversionReplies: 1Last Post: 5th Oct 2008, 13:13 -
MPEG2 > H.264 video converter with Dual audio streams?
By idsane in forum DVD RippingReplies: 8Last Post: 6th Aug 2008, 16:06 -
Best quality (Not speed) Converter for miniDV to Mpeg2
By AussieHusky in forum Video ConversionReplies: 5Last Post: 2nd Nov 2007, 01:54 -
Best AVI -> MPEG2 converter? (Freeware??)
By w@ntonsoup in forum Video ConversionReplies: 3Last Post: 13th Oct 2007, 23:58
