Results 1 to 9 of 9
  1. Member lowlow42's Avatar
    Oct 2002
    SW Florida
    Hi guys, hopefully you can help me out here. Please see files attatched so you understand what I am talking about. (Picture to see table & actual html file to check codes)
    What I want to do, is be able to have "Row 1" longer, and "Row 2" shorter. Is this possible in a table? If not, what can I do to make 2 lists, where 1 is longer than the other.
    Thanks in advance, any help is appreciated!
    Picture is here.... http://home.comcast.net/~homeboyj13/table.GIF
    HTML code is here.... http://home.comcast.net/~homeboyj13/example.html
    "The statement below is True,
    The statement above is False"
  2. Member thecoalman's Avatar
    Feb 2004
    Pennsylvania
    Nest two tables in one table.
  3. Member lowlow42's Avatar
    Oct 2002
    SW Florida
    Thanks for the reply, I'll try that now and post how it goes.
  4. Member thecoalman's Avatar
    Feb 2004
    Pennsylvania
    or something like this.... There's literally a 100 ways you can do it, best way is via CSS.
    <table width="100%" bgcolor="#FFFFFF" border="1" cellpadding="2" cellspacing="2">
    <tr valign="top">
    <td> left
    </td>
    <td rowspan="2"> right
    </td>
    </tr>
    <tr valign="top">
    <td border="0"> bottom
    </td>
    </tr>
    </table>
  5. Member lowlow42's Avatar
    Oct 2002
    SW Florida
    I just saw your last post. But here's mine before I try yours.
    http://home.comcast.net/~homeboyj13/table2.GIF
    http://home.comcast.net/~homeboyj13/example2.html
    Now I just want Row 2 to be Up instead of in the center.
  6. Member thecoalman's Avatar
    Feb 2004
    Pennsylvania
    And probably the easiest way to do it as I said with CSS.
    <html>
      <head>
    <style type="text/css">
     #leftcontent
      float:left;
      color: #000000;
      background: #FF0000;
      width: 300px;
      height: 600px;
      text-align: center;
      #rightcontent
      color: #FF0000;
      background: #000000;
      width: 300px;
      height: 300px;
      text-align: center;
    </style>
      </head>
      <body>
        <div id="leftcontent">
          Left Text
        </div>
        <div id="rightcontent">
          Right Text
        </div>
      </body>
    </html>
    The info in the style tag can be placed in a external document, name it format.css and add make sure to delete the style tags from the html doc and do not add them to the css doc.
    Add this between the head tags for an external stysheet, in this instance it should be the only thing between the head tags..
    <link rel="stylesheet" type="text/css" href="format.css">
    You can apply multiple formatting using CSS to a sngle tag or entir document. This is why it's so great. If you have a a large site and every html doc is linked to a single stylesheet you can for instance change the color of the background for the entire site just by changing a single line of code.
    http://www.w3.org/Style/CSS/
  7. Member lowlow42's Avatar
    Oct 2002
    SW Florida
    Ok Thanks, I appreciate your help... I'll most likely use that css code, it looks good.
  8. Member thecoalman's Avatar
    Feb 2004
    Pennsylvania
    If you follow that link I gave you you can see what other foramtting you can apply such as borders etc.
  9. Member lowlow42's Avatar
    Oct 2002
    SW Florida
    Yeah, when I clicked on it I saw some other stuff... I'm gunna read up on it. Thanks again
