Alright, I just bought a dvd recorder the other day.. It's awesome.. but I've noticed a couple times now there is buzzing in the sound for some reason.. Its happened on 3 channels now.. once on a record from 2-3 on WB, then another recording on ABC Family from 11-12, later on Game show network from like 2-3 am... I don't know whuts causing it.. I thought maybe cause the tv was turned up a little bit, (basically normal listening volume) well, so this time last night to record from 11-12 on ABC family, i turned it down where I could barely hear it.. well, halfway thru sounded like ic ould hear it while it was on tv.. so today I check my recording, and its on therewhus wrong? I recorded some stuff off MTV ( alot of stuff actually ) ..and it was fine! I have the ILO dvdr04 Thx guys
only_emo_kidGuest
The tuner in the ILO/ LiteOn recorders are not of the best quality and do have problems with noise and hum. Make sure you are using good quality cables to try and cut down on this.
Also, on page 12 in the manual, it shows how to fine tune each channel. You may want to try this on the channels giving you the most problem.
TV makes a buzzing sound when scenes are bright.
By Denvers Dawgs in forum Newbie / General discussionsReplies: 10Last Post: 30th Nov 2011, 11:32 -
Audio Sound File Saved - Canot Hear Sound - Total Recorder
By Teac23 in forum ComputerReplies: 1Last Post: 15th Apr 2011, 14:29 -
Looking for sound card recorder (not Total Recorder)
By jimdagys in forum AudioReplies: 1Last Post: 7th Jan 2011, 19:23 -
Ulead VideoStudio 10 + Dazzle DVD Recorder = No Sound???
By firebirdta84 in forum Capturing and VCRReplies: 1Last Post: 18th Jan 2008, 08:26 -
Western Digital WD2500JB 250GB making buzzing sound
By ChapGrip in forum ComputerReplies: 1Last Post: 26th Jun 2007, 17:17
