Is There a way to join 2 bin files or even 2 ISO file together?
Results 1 to 11 of 11
No.
BINs and ISOs are just "container" format - like buckets, they can contain anything. You have to extract what's inside (mount them with Daemon Tools) and see if there's anything that can be joined.
/Mats -
is there a way to burn 2 ISO files to a dvdr? usually use DVD decrypter to burn ISO files but i dont think it will let me add 2 ISO files. I hate to waste a 600mb iso file on a dvdr.
An iso is a disk image file, a 600 MB iso is probably a CD image file. You can either burn it to a CD or extract the information and burn it to DVD in the appropriate fashion. Without knowing what's in the iso it's not possible to give you an exact procedure. Isobuster will let you look at and extract from an iso.Originally Posted by rubberman"Art is making something out of nothing and selling it." - Frank Zappa
its a kids movie for my daughter. I did burn it to a cd but it wont play. he screen shows some files and folders.
Is it a VCD? SVCD? What "files and folders" do you see?
To carry on the bucket analogy, you can't make 2 buckets into one big bucket, but you can take one big bucket and pour what's inside the two smaller into the bigger.
/Mats -
when i burn the ISO using alcohol120 on a cdr i get the following on the screen:
root folder
data folder
directX folder
manual folder
am i burning it in the wrong format in alcohol120? -
Sounds more like you got the game version so it will never play on a dvd player for you.
Yes, that's not a movie, not in any known format, at least...
/Mats
joining files
By maxone71 in forum Video ConversionReplies: 0Last Post: 3rd Dec 2010, 20:33 -
Joining AVI Files
By wulf109 in forum Video ConversionReplies: 4Last Post: 4th Nov 2010, 14:17 -
bin files
By fredreed in forum DVD & Blu-ray PlayersReplies: 2Last Post: 15th Nov 2009, 01:02 -
Joining mpeg-4 files
By GAR in forum EditingReplies: 8Last Post: 3rd May 2008, 22:42 -
Joining avi files?
By t_jay17 in forum EditingReplies: 5Last Post: 18th Dec 2007, 12:22
