I have a captured avi from a DV-cam (panasonic nv-ds150).The quality of the sound is good. But after conversion to mpeg2, the its sound like "metal", the sound is very bad, I tried different tools with different settings, but nothing worked. I tried tmpgenc, with or without toolame, nero plug in. All with te same result,
I'm desperate....
Could the problem be my source? but when I play the uncompressed AVI, it sound good. I realy don't understand it.
Hi,
what kind of HW do you have?
I have more or less the same problem: avi to mpg1, sound is strange with crackles.
I have this problem with all tmpgenc versions and the Panasonic encoder 2.51.
The Ulead 6.5 encoder works, also the encoder of the Roxio VideoPack, but the image quality is not comparable to tmpgenc.
My HW is:
Athlon XP 1700++
Asus KT266A-E
512 MB RAM
OS does not matter: Win98 and WinXP
-jp
I'm desperate....
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
Get SSRC and use it as a sample rate converter for TMPGEnc, als ouse tooLame with it. -
Hi!
It's most probably the downconversion from 48kHz to 44.1kHz that tmpgenc does.
I don't know if your DV source is 48kHz, but after using ssrc as sampling frequency converter in tmpgenc when converting dvd's, my "metallic" my problem was gone!
It's worth the try!
Regards,
el-Dia -
Thanks!!!!
my problem is solved, I now use SSRC, (hard to fine!!!), and it works great!!!
thanks -
here is one link:
http://www.irradiance.net/NewStuff/Soft/ssrc-1.28.zip
Sound quality of Tmpgenc: Is it that bad?
By Banleno007 in forum Video ConversionReplies: 3Last Post: 15th Feb 2012, 21:10 -
No Audio In Encore/Bad Aspect Ratio/Bad Files/Bad ISO/Bad Everything
By koberulz in forum Newbie / General discussionsReplies: 35Last Post: 24th Jan 2010, 04:48 -
Video Conversion Fu - Why's My Encode So Bad?
By Keith Justice in forum Newbie / General discussionsReplies: 3Last Post: 1st Jan 2009, 20:08 -
new author w/ bad sound
By willmoodom in forum AudioReplies: 1Last Post: 12th Sep 2007, 14:23 -
Fixing bad PAL->NTSC conversion
By Goldmonkey2828 in forum Video ConversionReplies: 1Last Post: 30th Aug 2007, 19:40
