Hiho,
I just downloaded ffmpegX and tried to convert a DVD and some DVB recordings to AVI/MPEG2 (DivX and XviD, SVCD). But no matter which soundformat I choose (mp3, mp2, AC3) I never have sound in the renderd video. Any ideas what the problem could be?
Greets
Results 1 to 11 of 11
Here we go... This is a 5 sec sample (DVD -> AVI (XviD))
Thu Jun 9 17:37:17 CEST 2005
MEncoder dev-CVS-050123-19:55-3.3 (C) 2000-2005 MPlayer Team
Mac OSX static build for ffmpegX
AltiVec found
CPU: PowerPC
init_freetype
get_path('font/font.desc') -> '/Users/timsch/.mplayer/font/font.desc'
Font /usr/local/share/mplayer/font/font.desc loaded successfully! (206 chars)
libdvdread: Couldn't find device name.
Using Unoptimized OnScreenDisplay
Reading disc structure, please wait...
get_path('DVDKeys') -> '/Users/timsch/.mplayer/DVDKeys'
There are 10 titles on this DVD.
There are 39 chapters in this DVD title.
There are 1 angles in this DVD title.
DVD successfully opened.
success: format: 0 data: 0x0 - 0xfdf86000
[open] audio stream: 0 audio format: ac3 (5.1) language: de aid: 128
[open] number of audio channels on disk: 1.
[open] subtitle ( sid ): 0 language: en
[open] subtitle ( sid ): 1 language: de
[open] subtitle ( sid ): 2 language: iw
[open] subtitle ( sid ): 3 language: ar
[open] subtitle ( sid ): 4 language: no
[open] subtitle ( sid ): 5 language: en
[open] subtitle ( sid ): 6 language: de
[open] subtitle ( sid ): 7 language: en
[open] subtitle ( sid ): 8 language: de
[open] number of subtitles on disk: 9
DVD start cell: 0 pack: 0x0-0x5B16
DVD start=0 end=2080524
DVD Seek! lba=0x0 cell=0 packs: 0x0-0x5B16
Angle-seek synced by cell/vob IDN search!
Checking for YUV4MPEG2
ASF_check: not ASF guid!
Checking for Nullsoft Streaming Video
Checking for NuppelVideo
Checking for REAL
Checking for SMJPEG
Searching demuxer type for filename dvd://1 ext: (null)
Checking for MOV
Checking for VIVO
header block 1 size: 0
Checking for PVA
Checking for MPEG-TS...
TRIED UP TO POSITION 68938, FOUND 47, packet_size= 0, SEEMS A TS? 0
DVD Seek! lba=0x21 cell=0 packs: 0x0-0x5B16
Checking for LMLM4 Stream Format
Invalid packet in LMLM4 stream: ch=0 size=1140851708
LMLM4 Stream Format not found
system stream synced at 0x0 (13)!
==> Found video stream: 0
dvd_next_cell: next1=0x0
dvd_next_cell: next3=0x18
DVD Seek! lba=0xFDF0B cell=24 packs: 0xFBECF-0x10E06C
==> Found audio stream: 129
==> Found subtitle: 8
==> Found subtitle: 7
dvd_next_cell: next3=0x27
DVD Seek! lba=0x1FBE17 cell=39 packs: 0x1E0283-0x1FBF0C
--- END OF CELL !!! ---
dvd_next_cell: next1=0x27
dvd_next_cell: next2=0x27
MPEG Stream reached EOF
ds_fill_buffer: EOF reached (stream: video)
MPEG-PS file format detected.
Too many video packets in the buffer: (4096 in 8256071 bytes).
Maybe you are playing a non-interleaved stream/file or the codec failed?
For AVI files, try to force non-interleaved mode with the -ni option.
ds_fill_buffer: EOF reached (stream: audio)
MPEG: No audio stream found -> no sound.
Searching for sequence header... OK!
VIDEO: MPEG2 720x576 (aspect 3) 25.000 fps 7700.0 kbps (962.5 kbyte/s)
[V] filefmt:2 fourcc:0x10000002 size:720x576 fps:25.00 ftime:=0.0400
xvid: using library version 1.1.-126 (build xvid-1.1.0-beta1)
Opening video filter: [expand osd=1]
Expand: -1 x -1, -1 ; -1 (-1=autodetect) osd: 1
Opening video filter: [scale w=640 h=352]
SwScale params: 640 x 352 (-1=no scaling)
The selected video_out device is incompatible with this codec.
Crop: 720 x 436, 0 ; 70
Opening video decoder: [mpegpes] MPEG 1/2 Video passthrough
VDec: vo config request - 720 x 576 (preferred csp: Mpeg PES)
Could not find matching colorspace - retrying with -vf scale...
Opening video filter: [scale]
SwScale params: -1 x -1 (-1=no scaling)
Writing AVI header...
VDecoder init failed
Opening video decoder: [libmpeg2] MPEG 1/2 Video decoder libmpeg2-v0.4.0b
Selected video codec: [mpeg12] vfm:libmpeg2 (MPEG 1 or 2 (libmpeg2))
ODML: Aspect information not (yet?) available or unspecified, not writing vprp header.
dvd_next_cell: next2=0x0
DVD Seek! lba=0x6E26 cell=1 packs: 0x5B17-0xFF5F
DVD Seek! lba=0x439E cell=0 packs: 0x0-0x5B16
xvid: bitrate setting is ignored during first pass
VDec: vo config request - 720 x 576 (preferred csp: Planar YV12)
VDec: using Planar YV12 as output csp (no 0)
Movie-Aspect is 1.78:1 - prescaling to correct movie aspect.
VO Config (720x576->1024x576,flags=0,'MPlayer',0x32315659)
REQ: flags=0x443 req=0x0
REQ: flags=0x443 req=0x400
SwScaler: reducing / aligning filtersize 2 -> 2
SwScaler: FAST_BILINEAR scaler, from Planar YV12 to Planar YV12 using AltiVec
SwScaler: using FAST_BILINEAR C scaler for horizontal scaling
SwScaler: using n-tap C scaler for vertical scaling (YV12 like)
SwScaler: 720x436 -> 640x352
REQ: flags=0x403 req=0x0
REQ: flags=0x3 req=0x0
videocodec: XviD (640x352 fourcc=44495658 [DIVX])
xvid: par=0/0 (vga11), displayed=826x352, sampled=640x352
xvid: 2Pass Rate Control -- 1st pass
ODML: vprp aspect is 16384:6982.
*** [scale] Exporting mp_image_t, 720x436x12bpp YUV planar, 470880 bytes
*** [xvid] Allocating mp_image_t, 640x352x12bpp YUV planar, 337920 bytes
*** [expand] Direct Rendering mp_image_t, 640x352x12bpp YUV planar, 337920 bytes
Flushing video frames
Writing AVI index...
Fixing AVI header...
Video stream: 2763.275 kbit/s (345409 bps) size: 1740863 bytes 5.040 secs 126 frames
uninit video: libmpeg2
AltiVec found
CPU: PowerPC
init_freetype
Checking for REAL
Checking for SMJPEG
Checking for MOV
Checking for VIVO
Checking for PVA
dvd_next_cell: next3=0xD
cell: next1=0xD
dvd_next_cell: next2=0xD
dvd_next_cell: next3=0x13
13
dvd_next_cell: next2=0x13
and so on...
and so on...
xvid: 2Pass Rate Control -- 2nd pass -- bitrate=1265kbit/s
Encoding completed on Thu Jun 9 17:37:25 CEST 2005
Are you encoding directly from a DVD? It is adviced to rip a DVD first to your HD. Ripping only the main title (to one vob file) works pretty well.
I ripped it with MacTheRipper. Anyway, I have the same problem while converting my DVB recordings from eyetv...
Nope. I just tried it with the DVD (though track 2 doesn't exist) and with a DVB recording. Here's my logfile...Originally Posted by major
Thu Jun 9 23:30:11 CEST 2005
AltiVec found
CPU: PowerPC
MPEG-ES file format detected.
success: format: 0 data: 0x0 - 0xca7d1f8
Failed to open audio demuxer: /PATH TO MY AUDIO FILE/000000000858e229.mpa
VIDEO: MPEG2 720x576 (aspect 2) 25.000 fps 6327.6 kbps (791.0 kbyte/s)
[V] filefmt:1 fourcc:0x10000002 size:720x576 fps:25.00 ftime:=0.0400
Opening video filter: [scale w=320 h=240]
Opening video filter: [pp=md]
--- cut ---
Any idea what the problem is?! I have the same error with .ac3 files...
questions about audio normalizing and audio encoding
By codemaster in forum DVD RippingReplies: 2Last Post: 25th Sep 2011, 21:22 -
AVStoDVD crashed on audio encoding.. have m2v video file, but no audio
By arcooke in forum Newbie / General discussionsReplies: 3Last Post: 5th Aug 2010, 14:18 -
Help with audio encoding
By tooonami in forum LinuxReplies: 1Last Post: 11th Jul 2009, 18:55 -
encoding with DTS audio stream - Audio not found in AutoGK
By extrabyte in forum DVD RippingReplies: 1Last Post: 7th Jan 2009, 16:42 -
ffmpeg -- encoding while muxing new audio w/out source's audio, how ?
By vhelp in forum AudioReplies: 8Last Post: 21st Nov 2007, 19:53
