I have an avi movie file that is in dts audio format. I'd like to re-encode this movie to a dvd but audio softwares that I have can't seem to extract this dts format. Is there a software that can read this avi with dts audio and extract and convert it into a compatible wave file so that I can encode the movie into a dvd? I've tried virtualmod and was able to extract the wave stream but none of the sound editors can read this dts wave file. Thanks in advance.
why reencoding?
you can author your dts sound file in your dvd-video project with f.e. ifoedit!
is the demuxed audio from virtualdubmod correct -> checkit with f.e. gspot?
-> reencode your video stream with a mpeg2 encoder to MV2 (beware: dvd-video standard conform) mux/author your dts + mv2 to a new dvd-video project
if want to decode dts use tranzcode (I already posted it on this board)
dts conversion on mkv
By jack1234 in forum AudioReplies: 2Last Post: 13th Jun 2011, 04:51 -
Bluray PCM to DTS conversion
By HaZZaD in forum Blu-ray RippingReplies: 3Last Post: 6th Mar 2009, 20:10 -
eac3to conversion- thd->dts
By runLoganrun in forum AudioReplies: 0Last Post: 16th Dec 2008, 12:47 -
Belight settings for correct wave/ac3 volume conversion?
By spiritgumm in forum AudioReplies: 0Last Post: 29th Feb 2008, 12:19 -
DTS to stereo wave ?
By achtungpop in forum AudioReplies: 3Last Post: 3rd Dec 2007, 05:38
