I have a Sony DCR-HC32 Handycam and have been transferring video to my PC via a VCR through a video capture card using MovieMill. I ended up with a 2 minute, 3MB MPEG video clip. I finally bought a firewire card and connection and made the transfer to a DV AVI file (which I assumed would be much smaller) using Windows MovieMaker. Instead, I ended up with a 2 minute, 310MB AVI video clip. It's way better quality than the MPEG, but I want to make a teeny tiny file I can e-mail out. Any tips on how I can shrink this file?
You can also download MS's Media Encoder from there site, it's a little more robust in the options it has than Movie Maker. In either MM or the encoder you have to pick a profile or create one for what you want , the presets are labled accordingly.
If your going to e-mail the clip be aware that most mail servers will bounce e-mails with large file sizes. You ISP probably provides space for you to upload to there server, I'd suggest going that route.
Trying to Fix a Huge Corrupt .avi File!
By LPrime in forum Video ConversionReplies: 37Last Post: 15th Aug 2014, 23:01 -
I need to edit a huge .avi file
By Hobittual in forum EditingReplies: 2Last Post: 25th May 2010, 16:40 -
clip edited from avi-file is huge
By kjk in forum EditingReplies: 2Last Post: 14th Jan 2009, 13:45 -
Huge file after WMV to AVI conversion
By windranger in forum Newbie / General discussionsReplies: 8Last Post: 8th Apr 2008, 08:32 -
2 Small-ish AVI -> 1 Larger AVI = HUGE File. Why?
By cxp36 in forum Newbie / General discussionsReplies: 2Last Post: 6th Mar 2008, 18:31
) and then use either the High Quality video (large) or High Quality video (small) template. These use VBR and output at either 640 x 480 (large) or 320 x 240 (small).
