Results 1 to 13 of 13
    Apr 2005
    Ohio
    hi. i have a subbed video files. i was able to view the sub titles because of codecs. i went to back this up on a dvd but the subs arent there. is there any way to burn video WITH the sub titles included? i tried backing this up as a vcd with nero. TY ahead of time
  2. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    In what format are your subs? In what format is you "video files"?
    For VCD I use(d) the subtitler filter in VirtualDub, frameserve to encoder TMPGEnc).
    What are you trying to do? You mention "back this up on a DVD" but also "backing this up as a VCD". For VCD, the subs has to be encoded into the video itself, while for DVD, the subs are switchable as a separate stream.
    /Mats
    Apr 2005
    Ohio
    the video file is in avi format. how do i find the format of the subtitles? if im not mistaken, its DVobSub. i meant to say that i backed it up on cd as a vcd in nero. if u can tell me, what the best way to do what im trying to do. i want the subtitles included in the video once i back it up. TY ahead.
  4. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    For DVD, the "best" or "real" way is to create selectable subs. What's the extension of your subs?
    .srt?
    .sub + a .idx? (That's VobSub)
    .ssa?
    /Mats
    Apr 2005
    Ohio
    I know that its SSA but could you show me how to find the extension. Im new to this video editing and stuff. TY
    Dec 2004
    Australia
    File extensions are not specific to video editing. In folder options disable the hiding of known file extensions and you will be able to see the file extension. Although I wouldn't have thought that ssa would be associated with anything and therefor be visable anyway.
    Apr 2005
    Ohio
    maybe this will help because no extension popped up when i de-selected that option. it is a Japanese Audio Track as well as an internal subtitlestream. DirectVobSub is nessasry for displaying the subtitles. is the fact that its internal mean there is no extension? if so can i stll back this up and see the subtitles? if so how? TY
    Dec 2004
    Australia
    Well of course if the file has internal subs, then there is no external sub file to have an extension.
    What is the extension of the video file? mkv? ogm? mp4? avi?
    Shouldn't be a problem to demux the subs, then re-add them when your author your DVD.
    If you just want to burn it as a backup, then really the file should be bit identical once burnt. Therefor if it has subs before burning it should have them once burnt.
    Apr 2005
    Ohio
    its an avi file. let me rephrase that. i want to back it up as a vcd or dvd (which ever) so i can make a menu and create chapters. i tried to back it up as a vcd and the subtitles didnt display. hope this help. TY. anything i can try.
    Dec 2004
    Australia
    AVIMuxGUI can extract subs from avi's.
    Apr 2005
    Ohio
    ty very much. will AVIMuxGUI extract the subs even if the subtitles are hard coded?
    Dec 2004
    Australia
    No. That requires OCR. Recent betas of SubRip can do it, although I would imagine that most of the time it doesn't work that well.
    If an avi has hard encoded subs though, then the subs can't disapear when converting. Well unless you crop them off.
    Apr 2005
    Ohio
    ahh ok. im learning lol. TY very much. avimux is working great.
