This post was originally titled:
"MPG has nav packs so S2D doesn't add chapters ?"
1st, I learned that S2D adds chapters somewhere else, not in the MPGs
that it leaves alone if they are found to have nav packs.
I had a 7-title project and 3 of the titles came out with the wrong number
of chapters - a lot less chapters than they should have had.
Turns out the problem was in the MPGs which had been extracted from a
DVD.
I ran the 3 MPGs thru Womble MPEG-VCR, then re-ran the S2D project.
Not only did the chapters come out fine, but an AV sync problem which had
gotten progressively worse throughout those 3 titles was 100% cured.
Thanks to CB for mentioning Womble elsewhere
P-PA![]()
I followed the post by duhmez, July 4th, 2004 here:Originally Posted by CBC
https://www.videohelp.com/forum/viewtopic.php?t=228458
Then, to save trouble deleting and re VTSing etc in the saved S2D project,
I replaced the problem MPGs in the project folder with the 3 Wombled
MPGs - keeping the names the same as in the original project .S2D file.
Let me know if you need more help.
P-PA
SilverCrest - Saves as AVI?
By Okay in forum Newbie / General discussionsReplies: 8Last Post: 21st Oct 2011, 02:53 -
change aspect ratio in mp4box saves a few megs?
By silverwolf0 in forum Newbie / General discussionsReplies: 1Last Post: 10th Aug 2011, 05:19 -
Savetube saves - how to play?
By DaniBear in forum Software PlayingReplies: 6Last Post: 18th Apr 2010, 20:19 -
Giveaway of the Day - Womble MPEG Video Wizard DVD
By VirtualDoobMon in forum Latest Video NewsReplies: 45Last Post: 21st Sep 2009, 22:23 -
DVDFabdecrypter saves as .iso?
By magicfingers in forum Newbie / General discussionsReplies: 5Last Post: 7th Aug 2008, 09:01
