I am confused. I use adobe premiere 6 along with a matrox rt2500 card to edit video. I import wave music to my timeline and video clips. The outcome after I render, is an avi movie. My audio and avi movie come out seperated when exported as a movie. I can then take them and import them into TmpGenc plus, and they will be in sync.
Is my audio considered an avi audio or is it a wave audio after being exported as a movie in premiere? Will FFmpeggui accept it either way you look at it ?
Hi,
Avi is for video. Your output will be a wav file or another audio type such as mp2 or ac3.
Also a lot of programs will have default input formats so as long as you point it to your audio file it should recognize it automatically.
Kevin
(hope that helps.....)Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Thanks for answering my question. As far as the black video I don't think I ever seen that. I export as a matrox avi movie.
Automated Wave joiner.
By odomike in forum AudioReplies: 6Last Post: 28th Apr 2012, 03:26 -
Reduction of a wave file from 35 MB to 24 MB How?
By andy jackson in forum AudioReplies: 4Last Post: 1st Jun 2011, 12:41 -
Tsunami Wave on it's way here!
By budz in forum Off topicReplies: 20Last Post: 1st Mar 2010, 12:23 -
Convert DVD to WAVE
By edu-write in forum DVD RippingReplies: 1Last Post: 14th Dec 2008, 10:48 -
Wave Metadata
By loster in forum AudioReplies: 0Last Post: 1st Sep 2007, 10:45
