Hello i have a movie on 2 cdz and they are both in mpg2 . so my question is can i convert that to dvd format so i can watch it on my dvd player?? and if so what program do i use and is it EZ 2 use.. thanx
Hi,
If its already mpeg2 than it is in dvd format. Just load the mpg file into the dvd authoring program.
It will tell you if you its not to spec. If it isn't use tmpgenc plus to correct the file to the proper specs.
Just load the mpg file into the dvd authoring program. what program are you speaking of Nero dvd shrink etc???
that tmpgenc plus is too pricey for me at this time is there anything else i can use?? i tried to play the mpg cd in my dvd player and it wouldnt play. so my question is what can i do to get the movie thats on 2 cd-r'z to play in my dvd player.. Thanx 4 replyn and the help...
If it's 2 CDs and MPEG-2 then it's more than likely SVCD, which isn't DVD-compliant. Use the latest GSpot beta (2.52 I think) to check out the resolution, video bitrate, frame rate and audio type and see if they match the descriptions listed at www.videohelp.com/svcd . If not, post either them or a screendump from what GSpot tells you back here and we'll work out what you've got.Originally Posted by yoda313
If it is SVCD, then try https://www.videohelp.com/forum/viewtopic.php?t=129786 for some advice.If in doubt, Google it.
How can I convert MPG file recorded by progDVB into a regular MPG
By Aafour in forum DVB / IPTVReplies: 8Last Post: 16th Oct 2008, 14:51 -
I get ac3, mpg, mpg.s.mpg, .xml & .mpv instead of VIDEO_TS/DVD
By emanmb in forum ffmpegX general discussionReplies: 5Last Post: 18th Apr 2008, 15:48 -
VC-1 to Mpg-2 and MP4-AVC to Mpg-2
By Bruce Kuhn in forum DVD RippingReplies: 6Last Post: 10th Jan 2008, 18:06 -
Convert DVD TO MPG OR VOB TO MPG FOR FREE!!!!
By beetee123 in forum Video ConversionReplies: 9Last Post: 27th Jul 2007, 09:47 -
Spliting large mpg file into clips and saving each clip as a mpg file ?
By denise4gb in forum EditingReplies: 1Last Post: 6th May 2007, 18:52
