I understand using XP you don't have to instal any INCD software to allow you to drop and drag. Also I understand you have to make your CDRW drive the Master drive using the jumper on the back.
However, when I click in 'My Computer' it is still showing as a CD Drive (which I think should show CDRW Drive) and when I use explorer to drag file to that drive it does not allow me.
Please Please help as I have a lot of file to put on to some CDRW, and as NERO INCD latest version does not work with XP i'm stuffed.
Results 1 to 13 of 13
Did you try the WinXP Windows Update for burning issues? It solved me a lot of problems
What kind of a burner do you have?
Think I did, I got an update from Microsoft web page but this seems not to have done anything. Where did you get your update from. The burner I have is TDK CyClone 16/10/40.
In my XP Pro system, my Yamaha 2100E shows up as a Yamaha 2100E in device mgr, and in My Computer as a CD-RW drive.
I did have problems initially though.
It showed up as a CDROM drive in device mgr. I tried un-installing it, but it came back the same.
I finally went into my BIOS and disabled it, rebooted, shut down and re-enabled it in the BIOS.
Now it shows up OK.
Also, that update from MS was labeled as a CD-RW burner update, so make sure thats the one you got (if it dosen't show up as a CD-RW in My Computer though, I doubt the update will help). -
it will always say it is a cdr drive, go to drive properties and see if you have a tab for writting speed, if you do then XP see's it as a cdrw drive.
"it will always say it is a cdr drive"
I disagree. Mine says "CD-RW".
I can send you a screen shot if you don't believe me. -
Maybe it's in the drive firmware, I have a tdk velo with the latest firmware and it just says cdr, but I do have the recoding tab in properties so xp recognizes it as a cdrw and I can use cdrw media. And the screen shot is unessary, I believe you...lol
I installed XP and had similar problems. I found out that the problem was the hotfix update fro windows update. Just go to add or remove programs and uninstall the cd burner update, I think it is Q309691 ??? After uninstall you should be working. Don't worry if windows recognizes cd-rom t still works.
I uninstalled the hotfix but still drive is CD Drive in my computer, Not CD R or CDRW. I think I will give up soon,
If you give up, the terrorists - er, I mean, Bill Gates, will have won.
Kind of a late question, but do you have a record tab under drive properties?
Did you check TDK customer support web site? It may have a software update to make this work. I know my previous HP7200 was not recognized and HP just released a fix for it. In the mean time I just replaced it with an LG and it worked right out of the box.
sommersby, no there is no tab with record tab under drive properties, and in the meantime I have unistalled the drive and now every time I start windows it is asking me for a driver however I don't have one.
I have looked on the TDK web site, for a driver and some sort of fix but no joy.
So does any of you guys know where I can get a driver for the TDK Cyclone 16/10/40 which of course may fix this problem but may not!!
AVI on CDRW stops playing in DVD player?
By leonk in forum Newbie / General discussionsReplies: 10Last Post: 19th May 2012, 21:53 -
Removed Esata drive and replaced with another drive. New drive is now unus
By cal_tony in forum ComputerReplies: 6Last Post: 7th Feb 2012, 14:17 -
eSATA not hotpluggable with WinXP?
By PartingShot in forum ComputerReplies: 6Last Post: 13th Sep 2010, 19:59 -
CDRW Erasing Cancelled - CDRW NOT WORKing
By Sarao in forum ComputerReplies: 6Last Post: 5th Feb 2010, 10:55 -
2 SATA Drives - 1 drive letter in WINXP
By anthonyfellows in forum ComputerReplies: 8Last Post: 27th Feb 2008, 11:30
