I was converting an avi (video:mpeg4, audio mp3 44100 Hz stereo 192 kb/s) to DVD with ffmpeg and the following happened:
Video converted fine, but audio converting keeps hanging. It creates a 4kB wav and the process keeps running forever, but nothing will come out of it. No error message, the running process just won't produce an audio file and the info stops at the stream mapping.
Anyone experienced a similar problem? One of my suspects is QT7, because the problem never occured with QT6.
Results 1 to 10 of 10
QT won't play the mp3 audio (and plays the video only very jerky). Strange. Guess I'll try "decode with mplayer" and use mpeg2enc.
I've encountered this hang as well.
What I've do is use the "Movie audio to ac3" preset to encode the audio after the video has encoded and the process has hung on the audio. This avoids having to redo the video, and in every case the audio has encoded perfectly. Once both are done I proceeded to multiplex and author manually in the tools tab.
Cheers,
Alph.
The only POSSIBLE hint to the problem I've found is that if I run those problematic AVIs through Divx Doctor the video and audio tracks are of different lengths by up to 15 seconds at times.
I also figured out the movie -> ac3, but unfortunately this prevents batch conversion (I usually convert several avis during night or while I'm at work since it really takes some time on my old machine).
Strange that the direct sound conversion works, but not movie+sound.
Is there a way to just produce the mpeg2 video for muxing? That way I could still make batch conversion, like converting avi 2 video and then convert avi 2 audio. Then I could mux them manually after the lengthy conversion.
I tried it, but just unchecking the encode audio box won't work, because the resulting video is .mpg not .mpv or .m2v and won't be recognized for muxing.
So I still have to try out mpeg2enc with mplayer. Too bad that mpeg2enc is so frustatingly slooooooow on my machine.
Help!! Recorder hanging.
By mthomas90 in forum DVD & Blu-ray RecordersReplies: 1Last Post: 15th Aug 2010, 11:51 -
DVD FLick Audio Encoding Error on AVI videos produced by Canon camera
By patplh in forum Authoring (DVD)Replies: 18Last Post: 14th May 2009, 19:58 -
Ripbot264 hanging
By ma2kp in forum Blu-ray RippingReplies: 7Last Post: 13th Nov 2008, 10:59 -
dvd flick - hanging on audio encode
By ducky12 in forum Newbie / General discussionsReplies: 1Last Post: 11th Nov 2008, 03:50 -
Premiere CS2 hanging during simple tasks
By Schwez in forum EditingReplies: 2Last Post: 4th Oct 2008, 17:17
