I put some video from my MiniDV camera on my machine via FireWire using Vegas. Each tape gave me an avi file about 25 Gig in size. I cut each avi into smaller avi files in order edit them and author them to a DVD.
My problem is that if I do not reduce the size o fthese avi files than it looks like my vacation video may be a multi DVD set.
Thanks for your help.
When you author them to DVD, they will be encoded to mpg. This will surely reduce the size compared to their DV AVI incarnation. How much, depends on what bitrate you use when encoding. Don't know Vegas well enough to guide you, but there should be some "quality" setting or other to that effect, even if doesn't explicitly let you control the bitrate.
/Mats
Reducing the size of an avi file with Vegas 9.0
By solarblast in forum Video ConversionReplies: 10Last Post: 3rd Sep 2011, 23:01 -
Reducing video file size
By black5 in forum Newbie / General discussionsReplies: 2Last Post: 15th Jul 2010, 18:09 -
Limitingand reducing out file size
By TJF in forum Video ConversionReplies: 6Last Post: 7th Feb 2010, 10:25 -
Reducing AVI/DivX file sizes
By webstar in forum ffmpegX general discussionReplies: 5Last Post: 17th Jul 2007, 10:52 -
Reducing mpg file size
By sknox in forum MacReplies: 2Last Post: 3rd Jul 2007, 05:41
