I have a video that i made which is about 45 minutes long, I need to reduce it to about 3 miuntes for a demo.
I want to try to sqeeze in the best parts into the three minutes.
So I want to be able to cut the parts that i want and then connect them into a 3 minute demo movie.
I'm thinking I could run it through Tmg and cut and save the parts i want into format of choice and maybe append them in vdub.
But I'm sure there is a better way.
Please help
Some of these editors from Womble and others have fully-functional trials.
Womble mpeg vcr. But you'd be better off if you used the source material for your DVD rather than the DVD itself...
/Mats -
I think you're on the right track but I don't see where you need TMPGEnc unless you want your finished file to be MPEG.Originally Posted by MEANGUNS
I would use VirtualDub-MPEG2 (VirtualDubMod will work also) to edit and save as XviD/MP3 for a demo.
You may need to save the audio (AC3) as a Wave file and reinsert before editing the video.
Sorry, I thought it was an MPEG2 file for some reason. Any VirtualDub program will work but you will not get any transitions. There is a fade filter that you can use to fade in and fade out but it's a pain to do if you have alot of scenes.
Pro Video Editing Software Now FREE
By DJboutit in forum EditingReplies: 12Last Post: 5th Dec 2010, 05:53 -
What are the best free editing software?
By OM2 in forum EditingReplies: 7Last Post: 11th Apr 2010, 18:38 -
looking for free video editing software
By George2 in forum Newbie / General discussionsReplies: 17Last Post: 15th May 2009, 09:24 -
By plank spanker in forum Newbie / General discussionsReplies: 1Last Post: 5th Jan 2009, 19:42 -
Free .mov editing/tracking software?
By dubmunkey in forum EditingReplies: 6Last Post: 11th Jul 2007, 05:43
