Hi, I have two clips one is full dvd size and the other one is a vcd resolution, is it posible to author them with Ulead DVD workshop 2 without re-encode?
Also, I want to know can I author two different bite rate but same resolution clips in a sigle DVD without re-encode? or any other s/w can do it?
Thx
DVD WS will do that, I have 1.3 so these direction may differ. On the fi9nal burn menu there's a checkbox for "do not convert compliant files" By checking that it will only convert non-compliant files to whatever you picked for your disc properties.
Note that VCD audio is 44khz and needs to be converted to 48khz. Also note you can even put 16:9 and 4:3 on the same disc, matter of fact you can put any combination of files with different resolutions, bitrates, aspects...... they only need to be compliant to begin with. -
Originally Posted by guns1inger
Audio sync issue, Virtualdub, old video clips changing frame rate
By litmus in forum Video ConversionReplies: 1Last Post: 19th Sep 2011, 11:35 -
Canon HF21: Best Frame Rate And Resolution For YouTube?
By JohnnyGalaga in forum Newbie / General discussionsReplies: 14Last Post: 6th Aug 2011, 13:54 -
bit rate versus resolution
By topquark in forum Newbie / General discussionsReplies: 7Last Post: 24th Apr 2010, 09:25 -
bit rate vs resolution
By deadrats in forum Video ConversionReplies: 21Last Post: 26th Nov 2008, 20:23 -
mp3 bite rate to dvd .vob file
By koskofam in forum Newbie / General discussionsReplies: 7Last Post: 20th Nov 2008, 10:39
