Hi there
I have a r300 printer and all was working fine but now the paper jams all the time. dont matter what i do it still jams.
any idea?
dec
first you need to check the rollers to see if any small particles(paper,ink,ECT.)are trapped...they may be undetectable on the cd/dvd side, So gently push the cd/dvd tray in until it slides under the rollers...make sure that all the rollers on that side move as you slide the tray...check the other side as well. You won't be able to move the rollers on the other side but you might see something blocking the rollers. Put a sheet of paper in the paper tray and press the paper button....it should load the paper under the rollers....press it again and it should eject the paper. Check the paper holder(tray) to make sure there isn't any foreign objects in there. If all fails call Epson.LOL!
Is what we learn indeed a fact, or someones opinon? -
I actually have to clean my rollers with a moist q-tip (cotton swab) . They tend to collect small paper fibers which make it difficult for the rollers to grab the paper.
FCP jamming up with HD footage
By redbeard1970 in forum EditingReplies: 8Last Post: 3rd May 2012, 20:53 -
Putting paper labels on DVDs
By yznf in forum Newbie / General discussionsReplies: 10Last Post: 12th Feb 2012, 15:29 -
DVD Covers - What Paper?
By Nitro89 in forum MediaReplies: 12Last Post: 15th Apr 2009, 18:02 -
How to cut paper in curves
By wan2no in forum Off topicReplies: 4Last Post: 14th Sep 2008, 21:39 -
Best paper for cover printing?
By SilverBlade in forum MediaReplies: 31Last Post: 4th Jun 2008, 21:01
