Used virtualdub for the first time and it works AWESOME when joining multiple avi's together. However i noticed that after joining the avi files the file size is usually significantly larger. It is nearly double the size of the originials when combined together. Any ideas why or how to change it so its the same file size after being joined?
Thanks again
Make sure you set it to direct stream copy for both AUDIO and VIDEO!
There are 10 kinds of people in this world. Those that understand binary... -
Thanks for the suggestion. I had a problem when i tried joining the avi's together because of different sampling rates. So i searched on the forum and found that to solve this i had to save each individual avi with
audio - full processing mode and video
video - Direct stream copy
This fixed the problem but the file size was significantly larger. I will try setting both audio and video to Direct stream copy and see what happens.
thanks again -
Well that explains it then!Originally Posted by preludervtec
If the audio sampling rates are different (or it is VBR MP3), then follow the instructions about converting each avi to uncompressed audio.
Then, whnen you join them, you can re-encode the audio to Mp3 (if that is what you want) by using full processing mode for the audio in virtualdub.There are 10 kinds of people in this world. Those that understand binary...
Quick Question
By TagFan in forum DVB / IPTVReplies: 3Last Post: 26th Sep 2011, 09:45 -
quick question on sync in avi file
By Ogilvy in forum Newbie / General discussionsReplies: 2Last Post: 18th Oct 2009, 00:57 -
GOP length and filesizes (HCenc)
By Movie-Maker in forum Newbie / General discussionsReplies: 4Last Post: 19th Nov 2008, 10:41 -
How does it work from .avi to DVD with filesizes
By herbster in forum Authoring (DVD)Replies: 6Last Post: 10th Dec 2007, 19:17 -
Quick Question re: Joining mpgs
By boing in forum Newbie / General discussionsReplies: 10Last Post: 19th May 2007, 13:35
