My nero software seem to act funny on me by switching off by itself...
-I try to execute Nero it just doesn't excute.
-I try to uninstalled from Add and Remove, it also doesn't execute.
-When i try to go into it system-FOLDER (C:\Program\Ahead) it close by itself. (WTF)
-And when i try to going into its source folder (Stand alone file download from website) also close by itself. (WTF)
Did i get hack or something? I have never experience this problem before or something similar to this... Could anyone guide me on this case?
Thank you
Sounds very wierd indeed. I'd start with a virus and spyware scan. Do any other folders act this way ? If it is only associated with Nero, you could also try using the cleaner tools from ahead to remove nero completely, then reinstalling from scratch.
Read my blog here.
Yeah i am scanning both virus and spyware now, Other folder and file is normal only Nero... The things i cannot access any Ahead files, it just close down by itself...
I had extracted the folder that contain Nero source (Download Files from website) by using Firefox instead of Explorer... (Firefox doesn't close down when viewing any Nero files)
When i start to install the files source (Nero), it also closing by itself... (WTF) -
Wahh i just found out the problem... It the CD Karaoke which i was burning, if i put the CD in the drive it will automatic close down my NERO... If i eject the CD everything working well, is this something they invented to prevented from piracy?
This is crazy, i though i was being hack... anyway how do i burn this CD if i cannot use NERO, or do i have to try other software? (Maybe it still act the same?)
Thanx
EDIT: I've also notice when insert the CD it will autorun and open VLC media player... At the same time if i try to open Nero when VLC media still open the error message will display
Microsoft Visual C++ Runtime Library
Runtime Error!
Program: C:\Program Files\Ahead\nero\Nero\nero.exe
R6025
-pure virtual function call
If i close VLC media and open Nero nothing will happen... Wierd[/b] -
go to My computer icon, right click on your cd drive and select properties then turn off autorun or hold down shift key when you put a cd in your drive and hold it down until it settles and explore the drive after that don't click on it so nothing will load. Some cd's will load automatically even install spyware as soon as you put the cd in your drive.
VobBlanker acting strange
By pcb in forum Authoring (VCD/SVCD)Replies: 2Last Post: 4th Sep 2010, 18:00 -
Mp4cam2avi is acting up!
By 24fps in forum Video ConversionReplies: 3Last Post: 21st May 2010, 23:54 -
WinDV acting goofy
By stantheman1976 in forum Capturing and VCRReplies: 5Last Post: 8th Feb 2009, 20:46 -
iMovie acting up
By Nilfennasion in forum MacReplies: 4Last Post: 13th Nov 2008, 10:28 -
FCP acting strange
By James in HD in forum MacReplies: 1Last Post: 12th Oct 2008, 01:06
