I have detected a strange behaviour on a certain DVD navigation depending on the player... I am not sure whether the problem is in the DVD structure (after re-authoring) or in the player.
The First-Play PGC is:
Jump to VMGM PGC 3
The VMGM is as follows:
VMGM , LU 1 (en):
VMGM , LU 1 (en) , 1 (0:01) TitleM - Chapters: n/a, Programs: 1, Cells: 1
VMGM , LU 1 (en) , 2 (dummy) - Chapters: n/a, Programs: 0, Cells: 0
VMGM , LU 1 (en) , 3 (0:01) - Chapters: n/a, Programs: 1, Cells: 1
VMGM , LU 1 (en) , 4 (dummy) - Chapters: n/a, Programs: 0, Cells: 0
VMGM , LU 1 (en) , 5 (dummy) - Chapters: n/a, Programs: 0, Cells: 0
VMGM , LU 1 (en) , 6 (dummy) - Chapters: n/a, Programs: 0, Cells: 0
VMGM , LU 1 (en) , 7 (dummy) - Chapters: n/a, Programs: 0, Cells: 0
VMGM , LU 1 (en) , 8 (dummy) - Chapters: n/a, Programs: 0, Cells: 0
VMGM , LU 2 (it):
VMGM , LU 2 (it) , 1 (0:01) TitleM - Chapters: n/a, Programs: 1, Cells: 1
VMGM , LU 2 (it) , 2 (dummy) - Chapters: n/a, Programs: 0, Cells: 0
VMGM , LU 2 (it) , 3 (0:01) - Chapters: n/a, Programs: 1, Cells: 1
VMGM , LU 2 (it) , 4 (dummy) - Chapters: n/a, Programs: 0, Cells: 0
VMGM , LU 2 (it) , 5 (dummy) - Chapters: n/a, Programs: 0, Cells: 0
VMGM , LU 2 (it) , 6 (dummy) - Chapters: n/a, Programs: 0, Cells: 0
VMGM , LU 2 (it) , 7 (dummy) - Chapters: n/a, Programs: 0, Cells: 0
VMGM , LU 2 (it) , 8 (dummy) - Chapters: n/a, Programs: 0, Cells: 0
VMGM , LU 1 (en) , 3 contains a JumptoTitle 7
VMGM , LU 2 (it) , 3 contains LinkPGCn PGC 7
i.e. different commands. The effect is that, depending on which language is selected when the VMGM is entered, the navigation is different. The entry in the VMGM is selected by the First-Play PGC, so I assume that the selected language is decided by the player settings.
It has happened however that this DVD has been inserted in a player having "Italian" as preferred language, but the path corresponding to "English" has been followed instead. My question is: is this a problem in the DVD structure or in fault in the player? Shouldn't the player select the menu corresponding to the preferred language in the case illustrated?
yes, the player should select the LU that corresponds to the preferred language. It definitely looks like a player problem.
jeanlMenuShrink a free tool to shrink menus into stills with or without audio!
DVDSubEdit: a free tool to modify your subtitles directly inside the vob.
How to remove the language selection menu from BR Disc
By The-One in forum Authoring (Blu-ray)Replies: 21Last Post: 27th Apr 2014, 16:00 -
trouble with SVCD2DVD menu selection highlighting
By bobarnett in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 4th Sep 2011, 14:59 -
slow in menu selection for WMC wireless
By faridgh in forum Media Center PC / MediaCentersReplies: 0Last Post: 26th Apr 2011, 21:09 -
How to create the languege selection menu?
By ss213 in forum Authoring (DVD)Replies: 4Last Post: 5th May 2010, 02:59 -
Scene Selection Menu in DVD-lab Pro2
By jole in forum Authoring (DVD)Replies: 5Last Post: 25th Feb 2009, 03:20
