When i record tv programs in full anamorphic 16/9 format from sattelite or digital cable, i obtain a very nice picture quality.
But when burning them to dvd, the player or PC does not recognise them a widescreen format. they are still recognised as 4/3 altough the pichture is 16/9. which results in wrong settings on TV.
All the settings on my E85H are set to 16/9.
Anyone with the same experience?
greetings.
Results 1 to 9 of 9
If I encode a DVD like that I can only watch it on my widescreen 16:9 television which will 'stretch' the picture out to view it properly as it would have to when recieving the 16:9 signal from a digital reciever.
What I have to do to view a film recorded in this manner, on my widescreen tv, PC screen and my 5:4 portable tv (i.e. all quipment not just the one), is to encode it to 5:4 letterboxed.Cole -
Yes i know, i also only play it on my 16/9, or when i play it on my PC i change the settings.
But there must be some form of indication on a dvd that tells the player that the program is widescreen.
If you take an example of someone with a 4/3 Tv an and a DVD player with the correct settings. It will play any movie in letterbox and it will play my DVD as a stretched picture.
The E85H doesnt write that indication onto the DVD. -
you can change the 16:9 settings in the dvd ifo file with https://www.videohelp.com/forum/viewtopic.php?t=269033&highlight=ifoar2ws
I use DVD Patcher on the MPEG file to change the header from 4x3 to 16x9 (leaving the resolution specs as-is and specifying the same bitrate as before).
DVD authoring programs then see the file as 16x9 and create 16x9 DVD's from it. -
Originally Posted by Robert SimandlCole
I tried IFOAR2WS with success!
But this means burning the discs twice..
In other threads i see there are software upgrades for panasonic.
But i can't find out what they include..
Is it possible to re-edit a non-anamorphic dvd to anamorphic?
By Beautiful Alone in forum DVD RippingReplies: 45Last Post: 22nd Sep 2011, 09:00 -
Best way to convert 4:3/non-anamorphic DVDs to 16:9 anamorphic. HELP!!
By CoachSerpico in forum Video ConversionReplies: 9Last Post: 11th Feb 2010, 15:46 -
Problem capturing audio with most programs, any fixes? + Lagless programs?
By fgsfdsyo in forum Capturing and VCRReplies: 5Last Post: 15th Oct 2009, 16:51 -
Recording to DVD from Direct TV's system of organizing saved programs
By sarainelkins in forum DVB / IPTVReplies: 2Last Post: 15th May 2008, 09:51 -
recording tv programs
By kasfig in forum Newbie / General discussionsReplies: 20Last Post: 23rd May 2007, 11:40
