  1. Ok so i demuxed the movie.m2v and the AC3 audio from my dvd. I would like to rencode the movie.m2v with lower bitrate so i can fit it on one dvd5. I have CCE 2.67 but i cant open .m2v files in that so what do you suggest i do?
  2. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Load the M2V file via an AVISynth script.
    If in doubt, Google it.
  3. Ok i used DVD2AGI to make a d2v file then made a avisynth scrip with
    LoadPlugin("mpeg2dec3.dll")
    mpeg2source("movie.d2v")
    But when i load that avs in CCE it only says duration 10 minutes. Do you know of a better way?
    EDIT: Well ive searched all methods to use AVIsynth to open m2v but i cannot get CCE to see the correct duration. Everytime CCE says its 10 mins long.
