Ok, when i choose my burning options i choose DVD decrypter, and then below i select the tab for dvd decrypter, and create iso, do not burn.
when i goto due the process i choose do not burn.. it makes the folders perfectly, but won't create an ISO ??? I have to manually open up UltraISO or WinISO and make it myself... weird..
BLX
Can i see the log? Just the bit after "Done: Authoring DVD Folders"
It is because you have selected "Do not burn" when you started the process.
If you select it; it will just create the iso and not burn it to disc as that is what you have selected in the options. -
thanks nawa69..worked great... again sorry it took so long to respond... summer classes can be intense
blx
Where may I get the last version of the x264 - 64 bits version codec?
By daniel827 in forum EditingReplies: 5Last Post: 27th Dec 2011, 19:55 -
Mac version of VLC is less functional than the Windows and Linux version
By HitTheRoad in forum MacReplies: 12Last Post: 30th Oct 2011, 04:48 -
SUPER version 39 is broken - reinstall older version?
By castalla in forum Video ConversionReplies: 7Last Post: 3rd Nov 2010, 19:20 -
I convert mpeg2 to iso, then what? Can I covert iso to VOBs?
By BeerSnob in forum Newbie / General discussionsReplies: 3Last Post: 1st May 2008, 19:01 -
where to download old version of dvd fab??? error in new version
By willhenderson in forum Newbie / General discussionsReplies: 1Last Post: 1st Dec 2007, 17:00
