I have a DVD I want to edit, but it has an annoying feature.
This DVD has a layer break between a chapter (12th), so chapter 12 is split in cells 12 and 13.
It would be long to explain why I want to do this, but can someone explain how can I merge these two cells into one?
Code:VTS overview: Menu attributes: Video: MPEG-2 720x576 (PAL) (PAL 625/50) (4:3) (not specified perm.display) SubPicture 1: Not Specified (2-bit rle ) Title Set (Movie) attributes: Video: MPEG-2 720x576 (PAL) (PAL 625/50) (16:9) (letterboxed) Audio 1: Japanese (Dolby AC-3) 2ch 48Kbps DRC (ID: 0x80) Audio 2: Italiano (Italian) (Linear PCM) 2ch 48Kbps 16bps (ID: 0xa1) Audio 3: Italiano (Italian) (Linear PCM) 2ch 48Kbps 16bps (ID: 0xa2) SubPicture 1: Italiano (Italian) (2-bit rle ) (ID: 0x20) SubPicture 2: Français (2-bit rle ) (ID: 0x21) SubPicture 3: Español (2-bit rle ) (ID: 0x22) SubPicture 4: Deutsch (2-bit rle ) (ID: 0x23) SubPicture 5: Portugues (2-bit rle ) (ID: 0x24) SubPicture 6: Japanese (2-bit rle ) (ID: 0x25) SubPicture 7: Chinese (2-bit rle ) (ID: 0x26) PGC_1 (program chain): [Title(TTN): 1] [01:46:16.01 / 25 fps] (Programs: 20) (Cells: 21) (uses VOB-IDs: 1) [Ch 01] [Pg 01] [Cell 01] [V/C Id: 1/ 1] : time: 00:01:32.13 / 25 fps [Pos: 00:01:32.13] [Frames: 2313] SP/ILVU/DISC/SA:[ no/ no/yes/ no] [Ch 02] [Pg 02] [Cell 02] [V/C Id: 1/ 2] : time: 00:10:30.00 / 25 fps [Pos: 00:12:02.13] [Frames: 18063] SP/ILVU/DISC/SA:[yes/ no/ no/ no] [Ch 03] [Pg 03] [Cell 03] [V/C Id: 1/ 3] : time: 00:11:07.02 / 25 fps [Pos: 00:23:09.15] [Frames: 34740] SP/ILVU/DISC/SA:[yes/ no/ no/ no] [Ch 04] [Pg 04] [Cell 04] [V/C Id: 1/ 4] : time: 00:01:35.10 / 25 fps [Pos: 00:24:45.00] [Frames: 37125] SP/ILVU/DISC/SA:[yes/ no/ no/ no] [Ch 05] [Pg 05] [Cell 05] [V/C Id: 1/ 5] : time: 00:00:32.06 / 25 fps [Pos: 00:25:17.06] [Frames: 37931] SP/ILVU/DISC/SA:[yes/ no/ no/ no] [Ch 06] [Pg 06] [Cell 06] [V/C Id: 1/ 6] : time: 00:01:32.04 / 25 fps [Pos: 00:26:49.10] [Frames: 40235] SP/ILVU/DISC/SA:[yes/ no/ no/ no] [Ch 07] [Pg 07] [Cell 07] [V/C Id: 1/ 7] : time: 00:10:56.01 / 25 fps [Pos: 00:37:45.11] [Frames: 56636] SP/ILVU/DISC/SA:[yes/ no/ no/ no] [Ch 08] [Pg 08] [Cell 08] [V/C Id: 1/ 8] : time: 00:11:34.17 / 25 fps [Pos: 00:49:20.03] [Frames: 74003] SP/ILVU/DISC/SA:[yes/ no/ no/ no] [Ch 09] [Pg 09] [Cell 09] [V/C Id: 1/ 9] : time: 00:01:35.07 / 25 fps [Pos: 00:50:55.10] [Frames: 76385] SP/ILVU/DISC/SA:[yes/ no/ no/ no] [Ch 10] [Pg 10] [Cell 10] [V/C Id: 1/10] : time: 00:00:30.23 / 25 fps [Pos: 00:51:26.08] [Frames: 77158] SP/ILVU/DISC/SA:[yes/ no/ no/ no] [Ch 11] [Pg 11] [Cell 11] [V/C Id: 1/11] : time: 00:01:32.04 / 25 fps [Pos: 00:52:58.12] [Frames: 79462] SP/ILVU/DISC/SA:[yes/ no/ no/ no] [Ch 12] [Pg 12] [Cell 12] [V/C Id: 1/12] : time: 00:04:48.03 / 25 fps [Pos: 00:57:46.15] [Frames: 86665] SP/ILVU/DISC/SA:[yes/ no/ no/ no] [Cell 13] [V/C Id: 1/13] : time: 00:06:03.21 / 25 fps [Pos: 01:03:50.11] [Frames: 95761] SP/ILVU/DISC/SA:[yes/ no/ no/ no] [Ch 13] [Pg 13] [Cell 14] [V/C Id: 1/14] : time: 00:12:32.01 / 25 fps [Pos: 01:16:22.12] [Frames: 114562] SP/ILVU/DISC/SA:[yes/ no/ no/ no] [Ch 14] [Pg 14] [Cell 15] [V/C Id: 1/15] : time: 00:01:35.04 / 25 fps [Pos: 01:17:57.16] [Frames: 116941] SP/ILVU/DISC/SA:[yes/ no/ no/ no] [Ch 15] [Pg 15] [Cell 16] [V/C Id: 1/16] : time: 00:00:31.13 / 25 fps [Pos: 01:18:29.04] [Frames: 117729] SP/ILVU/DISC/SA:[yes/ no/ no/ no] [Ch 16] [Pg 16] [Cell 17] [V/C Id: 1/17] : time: 00:01:32.04 / 25 fps [Pos: 01:20:01.08] [Frames: 120033] SP/ILVU/DISC/SA:[yes/ no/ no/ no] [Ch 17] [Pg 17] [Cell 18] [V/C Id: 1/18] : time: 00:11:54.03 / 25 fps [Pos: 01:31:55.11] [Frames: 137886] SP/ILVU/DISC/SA:[yes/ no/ no/ no] [Ch 18] [Pg 18] [Cell 19] [V/C Id: 1/19] : time: 00:12:14.19 / 25 fps [Pos: 01:44:10.05] [Frames: 156255] SP/ILVU/DISC/SA:[yes/ no/ no/ no] [Ch 19] [Pg 19] [Cell 20] [V/C Id: 1/20] : time: 00:01:35.07 / 25 fps [Pos: 01:45:45.12] [Frames: 158637] SP/ILVU/DISC/SA:[yes/ no/ no/ no] [Ch 20] [Pg 20] [Cell 21] [V/C Id: 1/21] : time: 00:00:30.14 / 25 fps [Pos: 01:46:16.01] [Frames: 159401] SP/ILVU/DISC/SA:[yes/ no/ no/ no] Menu Language Units: 1 Language Menu Unit 1: [English] Language Menu Unit 1: [English] Menu 1: [Root-Menu] (entry PGC) (Programs: 0) (Cells: 0) Menu 2: [entry only] (Programs: 0) (Cells: 0) Menu 3: [entry only] (Programs: 0) (Cells: 0) Menu 4: [entry only] (Programs: 0) (Cells: 0) Menu 5: [entry only] (Programs: 0) (Cells: 0) Menu 6: [entry only] (Programs: 0) (Cells: 0) Menu 7: [entry only] (Programs: 1) (Cells: 1) (uses VOB-IDs: 1) Menu 8: [entry only] (Programs: 1) (Cells: 1) (uses VOB-IDs: 2) Menu 9: [entry only] (Programs: 1) (Cells: 1) (uses VOB-IDs: 3) Menu 10: [entry only] (Programs: 1) (Cells: 1) (uses VOB-IDs: 4) Menu 11: [entry only] (Programs: 0) (Cells: 0) Menu 12: [entry only] (Programs: 0) (Cells: 0) Menu 13: [entry only] (Programs: 0) (Cells: 0) Menu 14: [entry only] (Programs: 0) (Cells: 0) Menu 15: [entry only] (Programs: 0) (Cells: 0) Menu 16: [entry only] (Programs: 0) (Cells: 0) Menu 17: [entry only] (Programs: 0) (Cells: 0) Menu 18: [entry only] (Programs: 0) (Cells: 0) Menu 19: [entry only] (Programs: 0) (Cells: 0) Menu 20: [entry only] (Programs: 0) (Cells: 0) Menu 21: [entry only] (Programs: 0) (Cells: 0) Menu 22: [entry only] (Programs: 0) (Cells: 0) Menu 23: [entry only] (Programs: 0) (Cells: 0) Menu 24: [entry only] (Programs: 0) (Cells: 0) Menu 25: [entry only] (Programs: 0) (Cells: 0) Menu 26: [entry only] (Programs: 0) (Cells: 0) Menu 27: [entry only] (Programs: 0) (Cells: 0) Menu 28: [entry only] (Programs: 0) (Cells: 0) Menu 29: [entry only] (Programs: 0) (Cells: 0) Menu 30: [entry only] (Programs: 0) (Cells: 0) Menu 31: [entry only] (Programs: 0) (Cells: 0) Menu 32: [entry only] (Programs: 0) (Cells: 0) Menu 33: [entry only] (Programs: 0) (Cells: 0)
Here's what I would do (I haven't done it though so take it with a grain of salt). I'd use vobblanker (or decrypter) to extract the 2 cells in question, then demux (vobedit) and remux (muxman) them into a single cell. Then use vobblanker to remove one of the original 2 cells, and replace the other one with the one you created...
You could also use PgcDemux for your first step, it can demux a single cell (or two for that matter!).
jeanlMenuShrink a free tool to shrink menus into stills with or without audio!
DVDSubEdit: a free tool to modify your subtitles directly inside the vob. -
Thanks. Yes, it works, I did almost the same before (with Smartripper, Vobedit, and Ifoedit), but I hoped there was an easier way, like using a particular program or something in PGCedit.
Not that know of, but DVDRemake pro might be able to do that, although you'd have to check (and pay!)
can unnecessary VOB cells be not only blanked but deleted?
By q3mi4 in forum Newbie / General discussionsReplies: 0Last Post: 30th Oct 2008, 09:01 -
Extract Cells from dvd with memcoder
By banon in forum LinuxReplies: 0Last Post: 2nd Oct 2008, 01:15 -
Last 2 Vobs Unreferenced - should be 5 cells, only one shows, video there
By Laysan_A in forum Authoring (DVD)Replies: 1Last Post: 16th Nov 2007, 11:55 -
Chapters or Cells
By wulf109 in forum DVD RippingReplies: 5Last Post: 6th Jul 2007, 16:40 -
DVD Lab Pro - 2 cells issue
By GangstaRap in forum Authoring (DVD)Replies: 4Last Post: 24th May 2007, 09:44
