  1. How would I go about reversing a stereo recording... ac3 on divx mpeg
    Apr 2004
    Miskatonic U
    Reverse how ? Play it backwards, or swap left and right ?
    both will require demuxing all channels back to mono, and working from there.
    Read my blog here.
  3. Member brassplyer's Avatar
    Apr 2008
    Is it a single two track stereo audio? If it will load into Soundforge you could do a channel swap and save it that way. Or load it into Virtualdub, save the audio as a .wav file, do the same thing to the .wav file in Vdub using the mpeg version of Vdub, then save the video with the reversed audio with Vdub - under "audio" use "audio from another source" and save it to a renamed version of the video. Make sure you select "direct stream copy" for the video and audio.
    Why do you need to change the channels?
  4. It's a nearly seven year old thread, brassplyer, and Setite hasn't even visited here for three years.
  5. Member brassplyer's Avatar
    Apr 2008
    Info might be useful to someone. It came up in the related threads under one I inquired about.
  6. VirtualDub's advanced audio filter will allow you to swap channels. Just build a filter chain like this:
