I have severe problems producing new video in Studio 9+ when source material are interlaced and with different framerates (25 fps and 29.97 mixed).
First I tried framerate conversion of 29.97 fps clips to 25 fps with TMPGEnc 3.0 XPress but the embedded deinterlace in XPress 3 made the results terrible and jagging.
Any idea?
I wouldn't expect that you would need to remove interlacing. Just make sure all of the input files are the same frame rate. Also, some programs have issues if the input files are different resolutions.
Google is your Friend -
And do you know any smooth way of converting a 29.97 fps MPEG-2 stream to a 25 fps without deinterlacing?Originally Posted by Krispy Kritter
edit studio 6 jerking rendered material
By mistressa in forum EditingReplies: 1Last Post: 8th Sep 2009, 16:38 -
Can I capture DVD to edit? Pinnacle studio 12 ultimate
By photonianpa in forum EditingReplies: 1Last Post: 5th Mar 2009, 05:29 -
Edit 3 cam's with Pinnacle Studio 12 Yes you can
By Habby in forum Authoring (DVD)Replies: 2Last Post: 26th Jan 2009, 19:28 -
Trying to edit avi in Pinnacle Studio: PROBLEM!
By L3Wi5 in forum Newbie / General discussionsReplies: 5Last Post: 25th Sep 2008, 12:09 -
edit studio 6
By m baqar in forum Authoring (DVD)Replies: 0Last Post: 6th May 2008, 23:02
