Hi,
About a month ago I create three different rather large (>16GB) AVI files in After Effects. I exported them as an uncompressed 24-bit color Windows AVI files with no audio onto a USB hard drive formatted NTFS. At the time could view the file from the USB hard drive etc... and could import them into PPro.
Today however I can copy all the files from the USB hard drive to the computers hard drive intact at the same the size. However when I try to load them into PPRO I get an "Unsupported format or Damaged File" error message. I get something similar in AE, and in windows media player I get an "The file format is invalid" error. I get the same error if I try to do the same thing with the files on the USB hard drive.
The thing is I get this around 2 minutes and 18 seconds into the files. I calculated that this would end up being around the 4GB mark in the file. It does this for all three files. It also does this for one file that is around 6GB but this file plays completely through without any problems.
I did have to rebuild the computer which is a SuperMicro Motherboard, (2) WD 200GB HDs, 4 GB ram, WinXP Pro SP1.
Any ideas would be appreciated.
Originally Posted by sam hain
Hi thecoalman
thanks for your reply. When I rebuilt the computer I formatted the hard drives NTFS. After doing some research I'm finding that there's two versions of the AVI spec: AVI 1.0 and AVI 2.0 - I found some info on it here:
http://www.puremotion.com/forum/viewtopic.php?t=2710
I haven't installed the latest version of direct show but will post what happens. Hopefully updating directx will help. -
Hi thecoalman,
It doesn't matter if I play the file from the USB drive or copy it to my computer's hard drive. I can actually play the file but then about 1/4 the way through I get the error. I'm guessing that its because at the 1/4 mark is right around 4GB. The total length is around 16GB for instance. I looked at the file in a hex editor and the data is still there.
I'm wondering if I had installed something that allowed me to do that. I ran VirtualDub on a copy of the file and it 'fixed' the file at the same place I get the error (1/4 way mark/4GB).
I updated WinXP with the latest directX drivers but it still doesn't work. Very strange
Unsupported audio format in MKV file on LG 47LW5600 TV.
By kmplsv in forum Video ConversionReplies: 5Last Post: 23rd Feb 2012, 09:03 -
Unsupported format or damaged file -> ?
By ermetekos in forum EditingReplies: 1Last Post: 31st Mar 2010, 11:56 -
Unsupported FLV codec or format
By lovyagin in forum EditingReplies: 25Last Post: 11th Dec 2008, 23:13 -
Premiere 6.5 - unsupported compression format.
By vodmare in forum EditingReplies: 3Last Post: 28th Jan 2008, 16:51 -
damaged file(crc error) how to get it off dvd
By invadar in forum Newbie / General discussionsReplies: 4Last Post: 10th Jun 2007, 08:59
