  1. hi ... ive had a quick look arround but didnt find anything to help me with this
    i've got loads of short clips that im trying to get onto DVD, but i dont want them all to be in defferent titles, i would rather they were all in the same title and i could select which one i wanted from the chapters /??
    is this possible in DVD Lab
    thanks
  2. Member GeorgeW's Avatar
    Feb 2005
    In DVDLab Pro, you could try the "Movie Segment" feature (there are limitations and restrictions, so check the help files to see if it would work for you).
    I don't think it's available in the Standard version.
    George
  3. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    No, I've learned (the hard way) that DVD-Lab expects you to have your source material in order - one m2v/mpg, one title. If that's not to your liking, DVD-Lab is not the tool for you.
    /Mats
    Apr 2004
    Miskatonic U
    Movie segment is the closest you'll get in DVD Lab Pro, but you can't chapter it
    Read my blog here.
