Does anyone know how I can finalize discs recorded on a Panasonic DMR-E60 with a DMR-E50? The E50 plays the discs but says "Cannot Finalize" when I try to. I don't have the E60 anymore, darn it.
I tried to install the firmware update on the E50 but the display said "unsupported", which means it doesn't need it according to the Panasonic website.
Thanks!
-Randall
In the post located at https://www.videohelp.com/forum/viewtopic.php?p=1250162 I mentioned the following:Originally Posted by KeepItSimple
"The only other problem I had was when I recorded a DVD on my Panasonic DMR-E60, and tried to finalize it on one of my DMR-E20s. Apparently, those recorders use different internal recording formats, and the disc could not be finalized on either machine after the attempt, although could still be played on any of the recorders. "
After attempting to finalize the DVD on the wrong machine, it would play on each machine, but never could be finalized on either machine.
My solution was to rip the unfinalized DVD using ISOBuster, and using DVD creation software to create the menus for the ripped videos. -
Did you just burn the downloaded executable file directly on a CD or burn the actual firmware file after executing the downloaded file first? If it's the former, then you just did it wrong. Panasonic apparently forgot to tell people that they need to execute (double click) the downloaded file before burning the firmware file on a CD.Originally Posted by KeepItSimple
According to Panasonic's website http://www2.panasonic.com/webapp/wcs/stores/servlet/vDownloads?storeId=15001&langId=-1...ge=DVDFirmwareOriginally Posted by Synergy
it appears that you are supposed to just download the file, and copy it directly to a CD-R without execution on the PC first.
But you are right, the downloaded file must be uncompressed first on the PC, and the PANA_DVD.FRM file is the one copied to the CD-R. -
That's right. Now that I look REALLY close on the firmware update page it shows an illustration of the file that you're supposed to burn to the CD-R and the filename is PANA_DVD.FRM, which is what you get when you click on DMRE50.exe (the downloaded file). Thanks to y'all for the info and boo to Panasonic for leaving out a small detail that's essential to the plot.
So, KeepItSimple, were you able to update the firmware in your DMR-E50? And, did that solve your finalization problem??
Yes I was able to update the firmware after I burned the correct file to CD. I don't know if it will now finalize those discs from the DMR-E60 because I already finalized them on the new DMR-ES10 (a good DVD Recorder even though it doesn't have a bitrate display as earlier Panasonic models did
). BTW the discs I was trying to finalize were DVD-R, not DVD-RAM.
How to Finalize DVD Disc
By MI6 in forum DVD RippingReplies: 6Last Post: 22nd Jun 2012, 12:27 -
Panasonic DMR e60 ep no progressive out
By mammo1789 in forum Newbie / General discussionsReplies: 1Last Post: 2nd May 2012, 18:58 -
No space on disc to finalize
By Ordinary Joe2 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 6th Jan 2012, 09:54 -
Panasonic EZ28k; correct aspect BEFORE finalize... NOT after.
By D'oh! in forum DVD & Blu-ray RecordersReplies: 2Last Post: 7th Feb 2009, 08:10 -
Can you finalize a previously written disc?
By c5vetman in forum MediaReplies: 8Last Post: 28th Mar 2008, 09:16
