  1. I have recently installed TSCV Version 0.82 Beta release three. Everything works great until I try to write the bin/cue and burn. After creating still menus and chapters I click the "Create Cue/Bin" button and it takes me to the log tab. Then says the following:
    __________________________________________________ __________
    Starting VCDxBuild process...
    C:\Program Files\Video Programs\TSCV\TSCV.xml:128: validity error: Element videocd content doesn't follow the Dtd
    Expecting (option* , info , pvd , filesystem? , segment-items? , sequence-items , pbc?), got (info pvd filesystem segment-item segment-item sequence-items pbc)
    </videocd>
    parsing file `C:\Program Files\Video Programs\TSCV\TSCV.xml' failed
    VCDxBuild finished
    Possible Error: Please check your XML or send it to TSCV@ttool.de
    And stops. I have read a tutorial that shows step by step how to make the menus so I am pretty sure they are done correctly. Is it the beta version? If so, where can I get a non-beta version of the program? Thanks a lot!
  2. Were a bin/cue file generated? If so did you try to burn them?
