I have some VCD quality footage that I am trying to put on DVD. I have the video all set but then I try to convert the audio to 48000Hz. So I do a simple demux with TMPGEnc and it does not demux the whole audio file. Only part of it. So then I tried demuxing the audio in TMPGEnc with the tooLame (or lame I forget which) plugin and was successful. I was then happy to have a method that works perfectly. So then I tried this on another VCD and it does not work with either method.
Why would TMPGEnc have a problem demuxing audio from an MPG file? Could someone suggest another program to do so?
With BeSweet, would any one know how to set up the wizard so that it can use the tooLame and SSRC encoder?
-Machine
Originally Posted by Machine514
You can always try virtualdub for mpeg-1 or virtualdubMod for mpeg-1 and 2.There are 10 kinds of people in this world. Those that understand binary... -
Tried to have virtualdubmod extract the audio but it will only analyze the first 10 minutes of an hour clip!
So now it seems like it is an audio and video problem. I will repost in another forum.
-Machine -
Players can often skip over errors, sometimes with no noticeable problems. But any processing tool such as Tmpgenc or virtualdub will be less forgiving.
You could try bbmpeg if you can figure out how to use it!There are 10 kinds of people in this world. Those that understand binary...
Demuxing Problem
By jpmccusa in forum Authoring (DVD)Replies: 8Last Post: 18th Mar 2010, 19:10 -
Trouble converting(demuxing)
By VJep in forum Video ConversionReplies: 5Last Post: 24th Dec 2008, 23:43 -
Demuxing
By ckurowsk in forum Authoring (DVD)Replies: 5Last Post: 23rd Jul 2008, 17:04 -
what to do after demuxing?
By azizbhimani in forum SubtitleReplies: 2Last Post: 24th Feb 2008, 21:39 -
Converting or demuxing MKV's to another container using x264 or vc-1
By dm_0001 in forum Newbie / General discussionsReplies: 6Last Post: 9th Jan 2008, 14:19
