ok my computer seem to unable to copy files from a dvd disc..althlough it used to b4 formatting it, now i get this error:
CANNOT COPY: DATA ERROR (CYCLIC REDUNDANCY CHECK)
Have you tried multiple discs or does every disc give the error?Originally Posted by masri
You said it used to do it before formatting it. Do you mean that you have reinstall you OS and all softwares ? Is it possible that you are using any drivers that is different from before ? or missing some that you had but not now ? Yes, you should also try thecoalman's suggestion to see if the failure is on every DVD. How about CDs ? You have to know what works and what doesn't.
This error is normally associated with a damaged disc, eg scratches.Originally Posted by masri
Is the disc visibly OK ? -
My bet is on a damaged disk. But are you able to play that disk ?
When I was born I was so shocked that I could'nt speak for 18 months. -
disc is a lil scratched..but b4 i formatted computer it play ed fine..is there a way to fix tat error?
yes i did...the dvd copied some folders and some folders it didnt..Originally Posted by vcd_user
How to convert DV avi files to DVD ready MPG files with Win7 powershell.
By findus in forum User guidesReplies: 5Last Post: 19th Dec 2011, 17:42 -
How do I put AVI files onto a DVD as AVI files?
By dgarmaise in forum Authoring (DVD)Replies: 15Last Post: 17th Mar 2008, 21:32 -
DATA files rather than MPEG files from a DVD-Video?
By DieselsDen in forum Newbie / General discussionsReplies: 11Last Post: 14th Dec 2007, 04:24 -
Putting 2 QT Files w/ 2 seperate .srt files onto a DVD
By whoracle in forum ffmpegX general discussionReplies: 5Last Post: 22nd Jul 2007, 03:57 -
whats best to use to copy my home videos to DVD... avi files or wmv files??
By leegutcher in forum Newbie / General discussionsReplies: 5Last Post: 14th Jun 2007, 05:24
