Not sure if I should post this here - if not tell me to sod off and not the bore you..
just got a mercury kob br100 to network 2 machines - sick off my machine acting as a server. only now my daughter caun't get on msn messenger ( just hangs ). seems to work ok if i plug it into my surfboard directly, Need help setting up, anyone know how to get this to work..
both machines running XP and service pack 2...
Xp firewall swithed off
no documentation with the router.
many thanks
I've moved you through to the Computer forum.
ok i was a little confused at first but i think the br100 thing is a router right?
anyways im guessing the computers are able to access the internet through this router otherwize u would have noted otherwize.
this is my guess. the router has a built in firewall and is blocking various ip's and things. you will have to access its options somehow. and the only way to find out as routers vary is to check the venders website and hope it lists how there. -
Are these both wired? If so, try each port on the router, even the uplink port.
Windows Messenger
By Jomapil in forum ComputerReplies: 16Last Post: 11th Feb 2010, 09:06 -
messenger urgent help!
By alintatoc in forum ComputerReplies: 2Last Post: 1st Jun 2009, 09:39 -
Windows Live Messenger Problem
By Anakin in forum ComputerReplies: 0Last Post: 27th Feb 2009, 12:55 -
Msn Messenger
By gooberguy in forum ComputerReplies: 1Last Post: 18th Dec 2008, 12:42 -
MSN Messenger ring
By winifreid in forum ComputerReplies: 9Last Post: 10th Sep 2007, 18:15
