I've got an xvid file and the audio is sligtly out of sync with the video.
Firstly I stripped the audio from the file using virtual dub, then edited the audio stream by delaying by 700ms so they should now sync.
Im unsure though how to rejoin the audio and the video file again - tmpgenc only does mpeg files - is there anything i can use to rejoin the audio and video?
thanks
I'd use VirtualDubMod. NanDub should be an alternative.
/Mats -
In virtualdubmod load you avi, select streams and select add, then browse for your new audio file, load it in and then direct stream copy the whole file with another file name. If your old audio is still in audio streams then disable it before saving.
“He who makes a beast of himself gets rid of the pain of being a man.” -
All you need to do is load the avi in virtualdub and choose audio/interleaving/delay set to 700 and then save as new.avi with video/direct stream copy.No need to strip the audio at all.
mkv audio sync issues
By Bloodnut05 in forum Newbie / General discussionsReplies: 5Last Post: 15th Sep 2011, 05:06 -
Audio Sync Issues!!!!
By earthXDust in forum EditingReplies: 3Last Post: 30th May 2011, 00:23 -
audio sync issues.................
By landocass in forum Newbie / General discussionsReplies: 1Last Post: 26th Jul 2010, 17:48 -
Audio sync issues
By andy99 in forum EditingReplies: 7Last Post: 16th Sep 2008, 23:47 -
Audio Sync Issues
By Pinata in forum DVD RippingReplies: 2Last Post: 28th Jan 2008, 09:38
