    May 2005
    Oakville, Ontario, Canada
    I burned a movie. During the burning process using nero latest version suite, I got a message: The DVD-video files rellocation failed. The resulting dvd video might be unplayable. Do you want to continue." I continued with data verification option checked. Everything was successful, but when I try to play it in my dvd player I got a message saying "Wrong Zone". Can someone shed a light on this , please. Thanks
  2. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    "Wrong Zone" is most probably to do with trying to play PAL on a NTSC-only DVD Player, or vice-versa.
    "DVD-video file reallocation failed" generally means that there's something a bit dicey with your DVD structure.
    See:
    http://club.cdfreaks.com/showthread.php?t=85791
    https://www.videohelp.com/forum/archive/t226863.html
    http://www.avforums.com/forums/archive/index.php/t-137356.html
    https://www.videohelp.com/forum/viewtopic.php?t=261542
    https://www.videohelp.com/forum/viewtopic.php?t=266271
    You'd be amazed what you'll find when you type in the error message into google, or do an All Forums search here
    If in doubt, Google it.
