what program can i split the frames
and save them as indivial left and right not side by side
Originally Posted by nonex1
Your question does not make sense. Please explain more.There are 10 kinds of people in this world. Those that understand binary... -
sorry about that .
I am working with 3D movies that require a left and right frame of seperate info , when placed together that gives the 3D in shutter interlace
now I want to be able to seperate the frames and save them in seperate files , uptill now I can save them as one file but being side by side
bit of a tricky one -
Hmmm, not sure I really understand, but...
If I am thinking correctly, you can use virtualdub with the crop filter to 1st save the LH side, then adjust to save the RH side. You will then have two movies, one fro each side of the original.
If you then want to save these to a sequence of images, I think virtuladub can do this too. If not, TmpGenc will save a movie to a sequence of bmp files.There are 10 kinds of people in this world. Those that understand binary... -
what is this crop filter cant see it in the normal filter section , where can i get this one from
You don't want to use the crop function in VirtualDub. You want the Video -> Filters -> Add -> Deinterlace -> Unfold Fields Side By Side. If you want to restore the full picture height add a Resize filter after the unfolding.
If you want to split the video into two separate files (a left video and a right video) use the Discard Field 1 and Discard Field 2 options of the deinterlace filter. Set Discard Field 1 and save. The change to Discard Field 2 and save. Again you may want to resize to restore the aspect ratio.
Split video outside the key frames?
By KeyMs92 in forum EditingReplies: 14Last Post: 23rd Sep 2011, 06:53 -
Best program to split .ts audio from video?
By R55B in forum EditingReplies: 1Last Post: 30th Oct 2010, 08:09 -
Split xvid/avi at x MB instead of x frames/timecode
By Xavier in forum EditingReplies: 4Last Post: 3rd Mar 2009, 16:51 -
Split .tp files, which program?
By Strawjellybelly in forum EditingReplies: 2Last Post: 29th Jan 2009, 11:04 -
Captured AVI frames broken/split/badly aligned
By cyclometric in forum Video ConversionReplies: 3Last Post: 25th Sep 2008, 07:50
