hey, im thinking about getting an xbox soon, but i was wondering something.
once i get the remote and reciever for the xbox, what can it play? just normal store-bought dvds? can it play DVD-/+R's or DVD-/+RW's?
thanks
If you buy a new one should play every thing. The old Xbox had crap drives in them. This also goes for PS2 the first ones are not as good as the new ones.
There are a few different types od DVD drives that some in the XBOX, so it is hard to say. My XBOX sucks for playing DVD's. Even some comercial DVDs don't play in it. It won't play most DVD+Rs, but most of the +RWs I have tried have worked. I don't know anyone else that has as much trouble as I do, so you should be okay.
This plan is so bad, it must be one of ours. -
Good old google gave me this:
http://www.xbreporter.com/xboxdvddrivecomparison.php
Might be of some use
If in doubt, Google it. -
wait for the xbox 360!! It will play everything and the xbox will go bye-bye
Xbox 360 HD-DVD Player on PC
By WiReTaP in forum User guidesReplies: 48Last Post: 26th Dec 2008, 13:35 -
Amazon.com: $80 Xbox 360 HD DVD player + 6 HD DVDs
By louv68 in forum Newbie / General discussionsReplies: 2Last Post: 6th Feb 2008, 14:25 -
XBOX 360 HD-DVD Player problem
By maldb in forum DVD & Blu-ray PlayersReplies: 2Last Post: 14th Dec 2007, 20:25 -
Using the XBOX 360 HD DVD player on a PC
By the_importer in forum Media Center PC / MediaCentersReplies: 4Last Post: 12th Nov 2007, 21:39 -
By Tchail in forum Software PlayingReplies: 6Last Post: 10th Oct 2007, 15:07
