I have downloaded the program Dvdslideshowgui and frankly, I don't know if I am using it correctly. I seem to get the errors "Dvdsguio60 has caused an error in DVDGui060.exe. DVdgui060 will now close. ( I seem to get that one twice.) I also get the same error saying that the program has caused an error in kernel32.dll. I get these errors after creating a slideshow and then use the preview button.
I seem to be using the program according to the flash help file that is found on the DVDslideshowgui webpage.
Would anyone be able to offer advice or point me to some sort of help file on the subject? I can't seem to find much else on the subject. Also, has anyone had any expeience with any other DVD slide show freeware? This program seems to be a good one though if I could only figure out what I'm doing wrong. Thanks for any response!
I got the Arcsoft free trial and I have to say it is REAL easy to use. Many options, try it and I think you will like it. I know I like it way better than Dvdslideshowgui
http://www.arcsoft.com/en/support/downloads/demoversion.asp?title=30
good luckIf at first you don't succeed; call it version 1.0
do you know a good freeware hard drive copying program?
By edong in forum ComputerReplies: 10Last Post: 25th Aug 2016, 20:50 -
Any freeware program to get Nero off my computer
By maxamillion in forum Newbie / General discussionsReplies: 9Last Post: 11th Sep 2008, 14:12 -
What is a Freeware dvd program with these features?
By Milardo in forum Authoring (DVD)Replies: 4Last Post: 31st May 2008, 01:03 -
Freeware Music Editing Program
By LITEONDVD in forum AudioReplies: 3Last Post: 29th Sep 2007, 00:48 -
Freeware program that edits movies
By LITEONDVD in forum EditingReplies: 3Last Post: 21st Jul 2007, 10:25
