I had that happen a few years back when using TMPGEnc or even just editing without reencoding in Womble MPEG2VCR. The problem turned out to be my power supply's fan had stopped working and the CPU was overheating!
I'd say check all the fans on your PC, whether they be the CPU fan, power supply fan, chassis fan, make sure they're all turning.
You may also want to download SiSoft Sandra (sorry I don't know the link offhand but you can do a search for it at download.com), it can tell you your CPU temp at any given time.
Converting Xvid AVI to DVD
By rocks911 in forum Video ConversionReplies: 2Last Post: 21st Aug 2011, 20:24 -
xvid to dvd converting help
By victoriabears in forum Video ConversionReplies: 12Last Post: 15th Nov 2010, 21:00 -
Should you restart the cpu after converting or burning?
By macnolias in forum Newbie / General discussionsReplies: 8Last Post: 26th Nov 2007, 02:58 -
Converting .Xvid to DVD.... Please
By Galosat in forum Authoring (DVD)Replies: 2Last Post: 18th Sep 2007, 16:10 -
Converting from DVD to XVID
By morphjk in forum DVD RippingReplies: 11Last Post: 23rd Jul 2007, 17:33
