I am trying to author a DVD with two MPEGS, but one has AC3 audio and the other has MPEG audio. TMPGEnc will not let me use both clips. Is there any freeware that will convert the clip with MPEG audio to AC3 audio? If not, any commercial software that will do it?
Thanks,
Mark
you can author both without converting, just use separate tracks/vts for the mpegs. click add track in tmpgenc dvd author.
I tried separate tracks, but the two clips need to join smoothly and separate tracks caused a big jump.
I also multiplexed the video, but redwuz'r suggestion of just choosing a different audio source was something I didn't know about - worked beautifully and saved one generation of video.
DVD looks great - thanks for all your help!
Mark
Subtitles - progressive sync and incompatibility (srt and sup)
By sooojaded in forum SubtitleReplies: 3Last Post: 7th Feb 2012, 15:59 -
An MP4 with some incompatibility issues
By danielbb in forum Newbie / General discussionsReplies: 6Last Post: 2nd Jan 2010, 20:22 -
Windows Media Video DRM incompatibility w/ NVidia cards using TV out?
By Bix in forum ComputerReplies: 10Last Post: 18th Sep 2008, 19:36 -
disc incompatibility seg 3000
By bryanmansfield in forum DVD & Blu-ray WritersReplies: 2Last Post: 20th Mar 2008, 14:32 -
Encore/Video Wizard incompatibility with high bitrates?
By moxiecat in forum EditingReplies: 2Last Post: 20th Sep 2007, 15:29
