I recently bought the Pinnacle Studio DV firewire/software package for capturing video from my Sony D8 camcorder.
I upgraded to XP and discovered that the Studio DV software isn't supported under XP, but Studio 7 is...for an additional cost.
Right......
Obviously, Movie Maker kinda sucks, but does anybody have a somewhat basic video capture program they're using under XP?
Anybody have Premier 6 running on XP? Is there a favorite? Is there one that everyone hates?
Thanks!!
Virtual-Dub works very nicely, so long as your capture drivers are properly installed. I use it quite a bit with the Huffy codec. Works as well in XP as in 2000.
Basically, since you mentioned Premiere... if your capturing works there, it'll also work in V-Dub since it's more or less using the same drivers (at least it does no my AIW Radeon), only V-dub has much less overhead going on... -
I use AVI_IO for capturing and Adobe Premiere 6 for editing the stuff.
I use a Matrox Marvel G400 which captures video out of the box with native XP drivers and everything.
irc.webmaster.com port 6667 #DDR -
Virtual Dub won't do DV, will it? I thought DV AVI's weren't recognized in Virtual Dub.
Movie Maker is actually very good if you play around with the settings a little bit. The 2mbps 640x480 setting makes very goodlooking videos.
Premiere works just fine on XP, although for no-frills capturing, DVIO (freeware) is the best - it's a very small program - 64k maybe - and it doesn't drop frames for me at all whereas Premiere will from time to time for no apparent reason.
Embed Webcam Video Recorder in Every Post of My Forum for Users
By Dave234 in forum Video Streaming DownloadingReplies: 1Last Post: 22nd Mar 2012, 02:08 -
video capture problems - HV20 camcorder is controlled but no video capture
By chebowitz in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 14Last Post: 27th Feb 2010, 10:49 -
Any Kworld Capture Card Users: Help!
By rind1984 in forum Capturing and VCRReplies: 5Last Post: 3rd May 2009, 21:50 -
how do I make video available for downloading onto the users hard drive?
By frankri in forum MacReplies: 2Last Post: 9th Apr 2008, 15:42 -
capture advice: USB 2.0 video capture adapter?
By j jasper in forum Capturing and VCRReplies: 10Last Post: 26th Feb 2008, 19:18
